Go to Post While searching is not as glamorous, I'm certain you could find a lot of good resources related to this topic. - Katie_UPS [more]
Unread 21-01-2017, 10:10
mastachyra's Avatar
mastachyra mastachyra is offline
FRC #2781 (RoboPride)
mastachyra is just really nicemastachyra is just really nicemastachyra is just really nicemastachyra is just really nice
Re: Kitbot on Steroids 2.0
Originally Posted by Chris is me View Post
Change the gears out for Vex gears, put a plywood belly pan in and you're pretty much set, honestly.
I like switching to 4" wheels when possible to lower CG.
Why switch to aluminum Vex gears over steel AndyMark? I see Vex now has steel gears, but not in the sizes that might fit the Toughbox.
Just curious, have you seen this done? I assume the Vex gears wold have to machined down to 0.400" thickness to fit. Or maybe you meant replacing the whole gearbox.
Thanks
2014: EtaBot - MWR/30th place/no PO
2015: ThetaBot - MWR/30th place/no PO, R2OC/Winners, IndyRAGE 5th Alliance, WMRI QF
2016: IotaBot - MWR/16th place/QF, R2OC/7th Alliance Captain/QF, Boiler Bot Battle/6th place/Finalist
