Go to Post You definitely know you've overdosed on first when you wash the aluminum shavings off your hands AFTER you eat dinner. - Maxpower57 [more]
Unread 21-01-2017, 10:59
Freeman6499 Freeman6499 is offline
FRC #6499
Freeman6499 is an unknown quantity at this point
Declaration issues
Having syntax issues (bottom code). The declarations look correct to me, but I cannot determine what's wrong. Please provide feedback:
#include "GearCatcher.h"
#include "../RobotMap.h"
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=INCLUDES
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=INCLUDES
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=CONSTANTS
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=CONSTANTS
GearCatcher::GearCatcher() : Subsystem("GearCatcher") {
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DECLARATIONS
doubleSolenoid = RobotMap::gearCatcherDoubleSolenoid;
compressor1 = RobotMap::gearCatcherCompressor1;
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DECLARATIONS
void GearCatcher::InitDefaultCommand() {
// Set the default command for a subsystem here.
// SetDefaultCommand(new MySpecialCommand());
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DEFAULT_COMMAND
// END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DEFAULT_COMMAND
void GearCatcher::Open() {
doubleSolenoid->Set(1);
void GearCatcher::Close() {
doubleSolenoid->Set(-1);
void GearCatcher::Stop() {
doubleSolenoid->Set(0);
Unread 21-01-2017, 11:30
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Re: Declaration issues
Do you have your complete code on github? Or have the error you are getting?
Unread 21-01-2017, 17:41
FRC #6499
Yes,
There are a series of programs that are not being added to the path correctly.
It's asking for non-used paths such as
G++
Microsoft Visual 12.0
Description Resource Path Location Type
Program "C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\bin\amd64\cl" not found in PATH Getting Started2
Program "g++" not found in PATH
Unread 21-01-2017, 23:19
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Originally Posted by Freeman6499 View Post
Yes,
G++
Those won't affect deploying. You can safely ignore those.
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
