Go to Post One thing that FIRST has given me ... Friends who care. - Arefin Bari [more]
Unread 21-01-2017, 11:34
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
CANTalon C++ examples not compiling
Greetings!
Has anyone had any luck in getting the CTRE C++ examples to compile and link? I ran the latest installer from CTRE and it puts the includes and library off in ${WPILIB}/user/cpp/ which doesn't appear to be in the search path. By adjusting the build paths, I got the includes in place. But, the library isn't being found and I get a bunch of undefined symbols during the link.
Any clues as to what I'm doing wrong?
TIA,
Mike
Unread 21-01-2017, 12:14
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Re: CANTalon C++ examples not compiling
The libraries and include paths should be automatically getting updated by the plugins to point to the correct ${HOME}/wpilib/user/cpp folders (for includes) and files (for libraries) at Eclipse startup. Are the CTRE files actually installed in C:/Users/<your name>/wpilib/user/cpp/include and .../lib? There is a possible issue with the installer at present where if privileges are escalated (e.g. you're running as a normal user and need to type in an admin username/password) during install, the files will be installed into the admin user's wpilib directly instead of the user you're running the installer as.
Can you take a screenshot of the Includes section of your project?
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 21-01-2017, 12:47
Software Mentor
AKA: Mike Anderson
Greetings!
OK, I shut eclipse down and updated to the latest Java. started eclipse back up and it seems to be working now. :-) Using the neon.2 release of Eclipse with the latest WPILib version and Java V8 update 121. But, you've got to wipe out any old prolects and start clean because the old projects don't have the search paths set correctly.
Is there an easy way to update old project build specs without having to delete them?
Thanks for your help,
Mike
