Go to Post And just remember, it's an engineer's world. Without us, everyone is powerless, literally. - JoeXIII'007 [more]
Unread 21-01-2017, 11:28
Cybercats2872 Cybercats2872 is offline
FRC #2872
Cybercats2872 is an unknown quantity at this point
GRIP Full of Errors
I exported my GRIP stuff into a Java file (I'm not even sure I did it right, it only exports a .java so I copy pasted the text in that file into a class in Eclipse)
The code is riddled with errors, I'm the only programmer on my team and I'm struggling to understand what the issue is.
It's the standard GRIP code, I have an HSV Threshold, a mask, and a blob finder. In the Java code, lots of objects like VisionPipeline, Mat, and MatOfKeyPoint (and many more) are being flagged as nonexistent. What could be the issue?
Thanks!!!
Unread 21-01-2017, 12:25
SamCarlberg's Avatar
SamCarlberg SamCarlberg is online now
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Re: GRIP Full of Errors
Sounds like the Eclipse project isn't a WPILib robot project, which explains how it can't find all those libraries
WPILib
GRIP, RobotBuilder
Unread 21-01-2017, 14:05
FRC #2872
It is a WPLib and it recognizes many other objects such as Joysticks, just not anything from GRIP. Any ideas??
Unread 21-01-2017, 16:33
FRC #2084
VisionPipeline is new in WPILib this year. Have you updated the Eclipse plugins?
WPILib
GRIP, RobotBuilder
Unread 21-01-2017, 17:15
dmelcer9 dmelcer9 is offline
AKA: Daniel
FRC #0810 (Mechanical Bulls)
dmelcer9 is an unknown quantity at this point
Also for some reason we had to to this manually- make sure that opencv and cscore are included libraries. If you go to project properties > Java Build Path > Libraries, then "Add External JARs", select opencv and cscore in ~/wpilib/java/current/lib, that might solve the issue.
Unread 21-01-2017, 19:17
RushAHead RushAHead is offline
President and Pun-Master
FRC #3103 (Iron Plaid)
Team Role: Electrical
RushAHead is an unknown quantity at this point
We do C++, but it's still in Eclipse.
Did you export your code to Eclipse or copy in the code from a separate file? I had an issue earlier today with an imported file being corrupt and not recognizing anything (also refusing to even consider building), so I copied and pasted into a new project created from a random WPI-provided sample project.
In the new file, make sure your includes follow actual paths. You'll probably have to comment out/ remove the "#include <opencv2/contrib/contrib.hpp" unless you can find the folder. I was unable to, and commenting it out seems to have worked.
