Go to Post Dave doesn't predict the future. He creates it. - Alan Anderson [more]
Unread 21-01-2017, 14:21
AnnaCC's Avatar
AnnaCC AnnaCC is offline
FRC #4330 (Rambunction)
Team Role: Electrical
Rookie Year: 2015
AnnaCC is an unknown quantity at this point
Picking up fuel from the ground vs. using hoppers/retrieval zone
Hi everyone,
Our team is having a discussion about whether to spend the time/resources/robot space on an intake system for picking balls up off the ground or if we should just rely on the hoppers and retrieval zone. We're building a simple high goal shooter, but gears and rope climbing are our priorities.
Although running across the field to get fuel isn't ideal, we'll probably doing it anyway for gears, and if alliance partners cooperate to collect fuel from hoppers simultaneously (keeping as much off the floor as possible) we figured it wouldn't waste much more time to run across the field than run around the launchpad chasing balls.
Of course, it's easier to defend against a robot that can't pick up balls from the floor, and any missed shots become irretrievable. But we're a little more concerned about being able to do everything else well, I think.
What is your team doing about fuel? Anyone have any other insights?
Unread 21-01-2017, 14:25
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
Re: Picking up fuel from the ground vs. using hoppers/retrieval zone
Originally Posted by AnnaCC View Post
Hi everyone,
IMO, floor intake is the way to go. If designed properly, it shouldn't take up too much space (see RI3D team Indiana's robot). Also, you'd be able to collect from the floor while on your way to get gears.
It isn't shiny enough.
Unread 21-01-2017, 14:29
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
If you're going to have a robot that loads from the top from the hoppers, then you might as well make a little bit of space available for a ball intake. What ideas have your team come up with for that so far? Are there images or videos you have already found from which you can draw inspiration?
We're going for a top loading and floor intake.
Unread 21-01-2017, 16:23
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
I think a floor intake is absolutely essential for teams that want to be successful high goal shooters. However, you've already said that Gears and climbing are your priorities, NOT high goal shooting. If you are building mechanisms to retrieve and place Gears, a climbing mechanism, a high goal shooter, and a floor intake for Fuel, you will be effectively trying to build a robot that does everything. And as we see year after year, teams that try and do everything often fail to do any of the tasks well enough to set themselves apart. I think this'll be especially true this year. Another trend that I've seen quite a bit this year is teams that come to the conclusion that Gears are worth more points than Fuel, make Gears their top priority, and then invest much more of their time, robot space, and resources into shooting high goals. The point I'm trying to make is, if you've set out to make a Gear and climbing robot, make the best Gear and climbing robot you can. Don't divest resources from your primary scoring objective to add on a tertiary or quaternary capability.
Now, if you team feels strongly that you can add on a floor intake without detracting from the performance of your primary objectives, go for it! But this is an ever-present trap in FRC, and it catches many teams every year.
Unread 21-01-2017, 18:23
AnnaCC's Avatar
Rookie Year: 2015
We've been keeping up with Ri3D, and our original plan was to have a belt/elevator style intake like some of those bots. I think the issue is less a lack of ideas and more that we haven't started prototyping an intake yet. We've lost a bit of mechanical expertise over the past couple years and worried that if we spread out too thin, we could end up with an entire fuel-scoring system that doesn't work well.
^this. It seems likely that lots of teams will claim to prioritize gears/rope this year, decide that those mechanisms are fairly mechanically simple, focus on shooting, and then run into bugs later in the season that keep their "priorities" from working smoothly. Having to rely on hoppers or driving across the field for fuel during the match still makes me nervous, but hopefully our shooter will be able to just help us finish off the 40 kPa and score a few more match points when needed, and we won't have to rely on it as a main strategy.
Unread 21-01-2017, 18:40
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
Smile Re: Picking up fuel from the ground vs. using hoppers/retrieval zone
Hi everyone,
If our teams meet a team like you are suggesting ( hopper feeder ) our teams will spill all the hoppers first thing..
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 21-01-2017, 18:58
pntbll1313's Avatar
pntbll1313 pntbll1313 is offline
2052 Coach, Build/Electrical Mentor
AKA: Pete
FRC #2052 (KnightKrawler)
pntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud of
I recommend you think about your strategy for each stage of the competition. If you don't attend highly competitive regionals you should assume qualification matches will not have much FUEL being scored in the BOILER. That means there will not be much FUEL available after the start of teleop for you to use. If you face a strategic team they will dump all hoppers in the first 15 seconds of the match and make you try to outscore them at their game (I know teams in my area are already going to do this). In other words your great shooter may have about 1 hopper of benefit.
A very good High Efficiency GOAL scoring robot will be hard to build. If you are devoting that much into a great high goal scoring robot I would not want to only be fed by a HOPPER. Even at the Championship level I think winning alliances may have 2 GEAR focused robots. That means you would need to be the only shooter and after the first 20-30 seconds all you can contribute are the FUEL that has already been made and cycled back by the opposing alliance. So if you shoot 100% of their made shots you kept up.
Again this all depends on your team's goals. Think about what those goals are and the best robot to get you there
2016 (mentor/drive-coach)
Quarter-Finalist-Einstein, Winner-Carson Division Champs, Winner-10K Lakes, Chairman's Award-10K Lakes, Finalists-Lake Superior,
Winner-MSHSL Robotics Competition
2015 (mentor/drive-coach)
Finalists-10K Lakes, Finalists-Lake Superior, Finalist-MSHL Robotics Competition, Quarter-Finalist-Galileo Division Champs
2014 (mentor/drive-coach)
Winner-10K Lakes, Winner-Lake Superior Winner-MSHSL Robotics Competition, Quarter-Finalist-Galileo Division Champs
2013 (mentor/drive-coach)
Winner-10K Lakes, Winner-Lake Superior, Winner-MSHSL Robotics Competition, Quarter-Finalist-Newton Division Champs
2012 (mentor/drive-coach)
Finalists-Lake Superior, Semi-Finalist-MSHSL State Championship, Semi-Finalists at 10,000 Lakes
2008-2011 (college mentor)
2007 (driver)
Quarter Finalist-Milwaukee
Unread 21-01-2017, 19:09
Billfred's Avatar
Billfred Billfred is offline
We see the value of floor pickups for gears, and we hope to get to this point on our fuel-focused robot. But we will be starting off with a Team Indiana-style static holder and iterating from there.
Unread 21-01-2017, 19:25
Lady-of-Fandoms Lady-of-Fandoms is offline
AKA: Lenna Weiss
FRC #4131 (Iron Patriots)
Team Role: Scout
Rookie Year: 2015
Lady-of-Fandoms is an unknown quantity at this point
My team has made it a priority to collect from the floor. We're planning on implementing a slash-and-burn strategy of dumping all the hoppers before anyone else could get to them, thereby starving opposing teams of balls.
Unread 21-01-2017, 22:55
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Opposing teams who didn't design a floor pickup*
I assume even the most basic strategy discussion can come to the conclusion that hoppers can't be relied on
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 22-01-2017, 14:07
pmattin5459 pmattin5459 is offline
AKA: Patrick Mattin
FRC #5459 (Ipswich TIGERS)
Rookie Year: 2015
pmattin5459 will become famous soon enoughpmattin5459 will become famous soon enough
Yep. If our robot encounters any other shooters, we will dump every single hopper. It's a basic bit of defense that slows down many shooters' first pickup from a few seconds to however long it takes their floor pickup to fill their hopper (maybe around 5-10 sec?).
Unread 22-01-2017, 15:41
g_sawchuk's Avatar
g_sawchuk g_sawchuk is offline
Hmm.
AKA: Griffin Sawchuk
FRC #4476
g_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really niceg_sawchuk is just really nice
Sure, at a glance that's a fantastic strategy. However, let's look at some potential results.
If you do have a floor intake, I'll capitalize on the time you spend dumping the hoppers to squeeze in an extra gear cycle. That has the potential to make a big difference. Then, if you start scoring I will start cycling fuel in my retrieval zone, since you are feeding locations that I can load from. While you have the scoring lead, I have the gear lead (from when you were dumping hoppers).
Now, if you don't have a floor intake I'll start on gears, and just do gears continuously. I keep my one gear lead and you capitalize off of very little.
Not saying that hopper dumping (or better put, field reset's nightmare) is a bad strategy, just saying that it can be used against you.
FRC 2013-2015 (K-Botics #2809)
VEX 2015 - 2016 (W.A.F.F.L.E.S. #4476)
FLL 2015 - ??? (MechMasters #16931)
FRC 2016 - ??? (W.A.F.F.L.E.S. #4476)
2016 Dean's List Finalist
My thoughts and ideas do not necessarily reflect those of my team.
Unread 22-01-2017, 18:28
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
I think folks are drastically overestimating how long it will take to finish a serious hopper race. In any worthwhile race, the only hopper that's "up for grabs" is centerfield (boiler side)--within a few feet and a few seconds of being on the path to a gear cycle. All the other hoppers shouldn't be a fight if the loader and defender are worth the effort--one each at least ought to be done by the end of auto. In fact the defender could decide to hit the centerfield in auto, perhaps leaving their own launchpad hoppers for their allies to hit on their way out (for a gear or what have you). The second offensive hopper should be hit by a loader's ally (upon good advice) no later than the start of teleop on their way to gear running and potentially doubling as the loader's blocker to the centerfield hopper. If the centerfield hopper is indeed still full by teleop, both parties are left to decide whether and how to race for it. But if you really can finish a significant portion of an entire gear cycle while the defender hits that button (which you have to pass approximately as well), it's probably an easy decision and you have bigger things to worry about. Like Einstein.
Separately, note that in a situation where a hopper dump tactic is worthwhile, relying on a single-gear lead countertactic necessitates both the ability to predict alliances' final gear totals and the luck that they'll end up on a rotor split. If that one gear does just barely let you finish another rotor, more power to you--but if you're so close to the edge, that usually settles the debate as to what you should be doing that match. It's also highly unlikely that the other alliance will end up one full gear cycle behind you in that case. To do so would be a mistake on their part that signifies they're really not on your level anyway--either they blew their time cushion or they should have stopped much earlier upon realizing they'll be a gear short. (The alternative case is your own alliance wondering why you ran a random extra gear that doesn't turn a rotor.)
From a strategic design perspective, a non-floor loader who poses a threat (i.e. made this as a competent strategic decision and properly executes) is more likely a fast gear runner who does fuel opportunistically from the retrieval station while grabbing a gear. They ought to be very good at the centerfield hopper race, though it's not a bad strategy try to beat them on your way past. Other than that and an autonomus load, they won't be preoccupied with hoppers in competitive matches (mostly because they really won't take long). Strategically that design decision screams high-cycle gear runner with some extra space/weight and design time. (If they're underperforming, of course, as with all defense the defender needs to reconsider pre-match whether it's worth bothering.)
Unread 22-01-2017, 18:37
g_sawchuk's Avatar
Hmm.
FRC #4476
I openly welcome you to risk 140 points during eliminations for the single gear that you don't complete because you wanted to dump the hoppers (or 50 for a hang that you might have not had time for as you raced to complete your 4th rotor).
I'm not quite sure as to why you think getting this one gear lead hurts you - you're working towards scoring while they're trying to counter you on a task you aren't targeting that match.
Please note that I never said if a floor intake or hopper intake was better - I think the others on this thread made that abundantly clear. Just providing insight with regard to countering hopper intakes.
We can apply plenty of levels of play to my suggestion - my thoughts are targeted towards a near-average level match up (perhaps slightly above).
Unread 22-01-2017, 18:46
Chris is me's Avatar
AKA: Pinecone
Focus on your priorities. If a floor pickup takes time or resources or space away from gears and climbing, ditch it. If it doesn't, go ahead, that will have nonzero value. That's pretty much what it comes down to.
You'll be able to have some sort of ball game with human loading only. I don't think it's absolutely mandatory to floor pickup in this game.
