Picking up fuel from the ground vs. using hoppers/retrieval zone
Hi everyone,
Our team is having a discussion about whether to spend the time/resources/robot space on an intake system for picking balls up off the ground or if we should just rely on the hoppers and retrieval zone. We're building a simple high goal shooter, but gears and rope climbing are our priorities. Although running across the field to get fuel isn't ideal, we'll probably doing it anyway for gears, and if alliance partners cooperate to collect fuel from hoppers simultaneously (keeping as much off the floor as possible) we figured it wouldn't waste much more time to run across the field than run around the launchpad chasing balls. Of course, it's easier to defend against a robot that can't pick up balls from the floor, and any missed shots become irretrievable. But we're a little more concerned about being able to do everything else well, I think. What is your team doing about fuel? Anyone have any other insights? |
Re: Picking up fuel from the ground vs. using hoppers/retrieval zone
If you're going to have a robot that loads from the top from the hoppers, then you might as well make a little bit of space available for a ball intake. What ideas have your team come up with for that so far? Are there images or videos you have already found from which you can draw inspiration?
We're going for a top loading and floor intake. Last edited by bEdhEd : 21-01-2017 at 14:31. |
I think a floor intake is absolutely essential for teams that want to be successful high goal shooters. However, you've already said that Gears and climbing are your priorities, NOT high goal shooting. If you are building mechanisms to retrieve and place Gears, a climbing mechanism, a high goal shooter, and a floor intake for Fuel, you will be effectively trying to build a robot that does everything. And as we see year after year, teams that try and do everything often fail to do any of the tasks well enough to set themselves apart. I think this'll be especially true this year. Another trend that I've seen quite a bit this year is teams that come to the conclusion that Gears are worth more points than Fuel, make Gears their top priority, and then invest much more of their time, robot space, and resources into shooting high goals. The point I'm trying to make is, if you've set out to make a Gear and climbing robot, make the best Gear and climbing robot you can. Don't divest resources from your primary scoring objective to add on a tertiary or quaternary capability.
Now, if you team feels strongly that you can add on a floor intake without detracting from the performance of your primary objectives, go for it! But this is an ever-present trap in FRC, and it catches many teams every year. |
A very good High Efficiency GOAL scoring robot will be hard to build. If you are devoting that much into a great high goal scoring robot I would not want to only be fed by a HOPPER. Even at the Championship level I think winning alliances may have 2 GEAR focused robots. That means you would need to be the only shooter and after the first 20-30 seconds all you can contribute are the FUEL that has already been made and cycled back by the opposing alliance. So if you shoot 100% of their made shots you kept up. Again this all depends on your team's goals. Think about what those goals are and the best robot to get you there ![]() Last edited by pntbll1313 : 21-01-2017 at 19:04. |
#8
We see the value of floor pickups for gears, and we hope to get to this point on our fuel-focused robot. But we will be starting off with a Team Indiana-style static holder and iterating from there.
#9
My team has made it a priority to collect from the floor. We're planning on implementing a slash-and-burn strategy of dumping all the hoppers before anyone else could get to them, thereby starving opposing teams of balls.
#10
I assume even the most basic strategy discussion can come to the conclusion that hoppers can't be relied on ![]() |
#11
Yep. If our robot encounters any other shooters, we will dump every single hopper. It's a basic bit of defense that slows down many shooters' first pickup from a few seconds to however long it takes their floor pickup to fill their hopper (maybe around 5-10 sec?).
#12
If you do have a floor intake, I'll capitalize on the time you spend dumping the hoppers to squeeze in an extra gear cycle. That has the potential to make a big difference. Then, if you start scoring I will start cycling fuel in my retrieval zone, since you are feeding locations that I can load from. While you have the scoring lead, I have the gear lead (from when you were dumping hoppers). Now, if you don't have a floor intake I'll start on gears, and just do gears continuously. I keep my one gear lead and you capitalize off of very little. Not saying that hopper dumping (or better put, field reset's nightmare) is a bad strategy, just saying that it can be used against you. |
#13
I think folks are drastically overestimating how long it will take to finish a serious hopper race. In any worthwhile race, the only hopper that's "up for grabs" is centerfield (boiler side)--within a few feet and a few seconds of being on the path to a gear cycle. All the other hoppers shouldn't be a fight if the loader and defender are worth the effort--one each at least ought to be done by the end of auto. In fact the defender could decide to hit the centerfield in auto, perhaps leaving their own launchpad hoppers for their allies to hit on their way out (for a gear or what have you). The second offensive hopper should be hit by a loader's ally (upon good advice) no later than the start of teleop on their way to gear running and potentially doubling as the loader's blocker to the centerfield hopper. If the centerfield hopper is indeed still full by teleop, both parties are left to decide whether and how to race for it. But if you really can finish a significant portion of an entire gear cycle while the defender hits that button (which you have to pass approximately as well), it's probably an easy decision and you have bigger things to worry about. Like Einstein.
Separately, note that in a situation where a hopper dump tactic is worthwhile, relying on a single-gear lead countertactic necessitates both the ability to predict alliances' final gear totals and the luck that they'll end up on a rotor split. If that one gear does just barely let you finish another rotor, more power to you--but if you're so close to the edge, that usually settles the debate as to what you should be doing that match. It's also highly unlikely that the other alliance will end up one full gear cycle behind you in that case. To do so would be a mistake on their part that signifies they're really not on your level anyway--either they blew their time cushion or they should have stopped much earlier upon realizing they'll be a gear short. (The alternative case is your own alliance wondering why you ran a random extra gear that doesn't turn a rotor.) From a strategic design perspective, a non-floor loader who poses a threat (i.e. made this as a competent strategic decision and properly executes) is more likely a fast gear runner who does fuel opportunistically from the retrieval station while grabbing a gear. They ought to be very good at the centerfield hopper race, though it's not a bad strategy try to beat them on your way past. Other than that and an autonomus load, they won't be preoccupied with hoppers in competitive matches (mostly because they really won't take long). Strategically that design decision screams high-cycle gear runner with some extra space/weight and design time. (If they're underperforming, of course, as with all defense the defender needs to reconsider pre-match whether it's worth bothering.) |
#14
I'm not quite sure as to why you think getting this one gear lead hurts you - you're working towards scoring while they're trying to counter you on a task you aren't targeting that match. Please note that I never said if a floor intake or hopper intake was better - I think the others on this thread made that abundantly clear. Just providing insight with regard to countering hopper intakes. We can apply plenty of levels of play to my suggestion - my thoughts are targeted towards a near-average level match up (perhaps slightly above). |
#15
Focus on your priorities. If a floor pickup takes time or resources or space away from gears and climbing, ditch it. If it doesn't, go ahead, that will have nonzero value. That's pretty much what it comes down to.
You'll be able to have some sort of ball game with human loading only. I don't think it's absolutely mandatory to floor pickup in this game. |
