Go to Post My nagging fear is that I'm a programming dinosaur, stuck in a procedural tar pit and doomed to extinction as the dataflow mammals take over. - Alan Anderson [more]
Unread 21-01-2017, 16:23
Eryl2000's Avatar
Eryl2000 Eryl2000 is offline
FRC #3024 ("My Favorite Team")
Eryl2000 is on a distinguished road
Camera to use for Vision Processing
Hi,
We are trying to vision processing, but we're not sure which camera is best to use. Last year we implemented vision control, but we had a lot of problems getting consistent results. The images we got were fairly whitewashed, which might be because our ring light was not bright enough, but I don't know if a brighter ring light would have even helped. The images were not really good enough to properly edge find with. I heard that changing the exposure on the camera can help fix this problem, but I'm not sure which cameras can do so and which ones do it best.
Any help would be appreciated!
Unread 21-01-2017, 16:28
NShep98's Avatar
NShep98 NShep98 is offline
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud of
Re: Camera to use for Vision Processing
What kind of camera and ring light were you using before? A pretty standard setup could be this camera and this ring light. This is not the only option, but it's what my team is going with.
FRC 2079 - 4H ALARM Robotics 2015 - 2017
FLL 2011, 2013
Unread 21-01-2017, 16:31
Eryl2000's Avatar
We used those exact parts last year with minimal success. We also used the Axis 206. We weren't sure how to set the exposure (if it is even possible on those).
Unread 21-01-2017, 16:38
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
I'm not sure about being "best" but a lot of teams use the Microsoft HD3000 camera probably because it's often times available in the KOP or FIRSTChoice. We've used the Axis cameras because that's what we had. It's a far more expensive camera with a built in web server so it connects via ethernet.
There is a lot of support for both of these on Chief Delphi. I'd be interested if someone has found a camera that's better for FRC applications.
Yes, it is vital that you be able to control the exposure. You want to turn it WAY down so that your camera only sees the tape and other really shiny things.
A few other tips. Don't try to image process while the robot is moving (at least in the beginning.) Many teams use a image co-processor but it may not be required depending on what you are trying to do. The Cheesy Poofs, 254, have a lot of resources on how their image processing works. You could do worse than studying their materials carefully.
Unread 21-01-2017, 21:00
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
I thought the pixy was easy to get working, in all honesty we probably over thought the entire setup from the get go, but it turned out pretty simple so far.
Unread 21-01-2017, 22:46
euhlmann's Avatar
euhlmann euhlmann is online now
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Last year we used a Logitech C930E. It has decent exposure and white balance control, and (the reason we picked it) a wide field of view.
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 22-01-2017, 09:01
gerthworm's Avatar
gerthworm gerthworm is offline
Making the 1's and 0's
FRC #1736 (Robot Casserole)
Rookie Year: 2015
gerthworm has a spectacular aura aboutgerthworm has a spectacular aura about
All the green smaller rings are out of stock till April.... I guess amber might be another good option? Anyone had luck with those?
Unread 22-01-2017, 09:55
rudun's Avatar
rudun rudun is offline
FRC #0496 (Royals)
rudun is an unknown quantity at this point
They are available on black circuit boards also.https://www.superbrightleds.com/more...it-board/1117/
Unread 22-01-2017, 10:29
beijing_strbow beijing_strbow is offline
FRC #5968 (Cyborg Indians)
Rookie Year: 2016
beijing_strbow is an unknown quantity at this point
We're using a Microsoft LifeCam HD-3000 for vision processing this year and it seems to be working fairly well (that's my general impression - I'm mostly working on something else). They're very cheap and easy to work with, considering that the WPI libraries were built for them.
You can fix the whitewashing by turning the exposure and brightness way down (I think we have it set at 1% on both of them, and it works pretty well).
Unread 22-01-2017, 10:35
Billfred's Avatar
Billfred Billfred is offline
Garnet Squadron ran an RGB ring light at Palmetto last year. If I remember correctly, we actually introduced a little pink to ours and were able to track the reflective tape at home. (At the event, we quickly realized our RasPi had a glass jaw.)
Unread 23-01-2017, 00:08
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
We've used amber in the past with mixed results. We're switching to green this year. Amber seems to be a more common color produced by house lights, etc. We were getting more noise than we do with green.
