Go to Post IT ISN'T THE STUDENT'S JOB TO DISCIPLINE OTHER STUDENTS. That's why God invented mentors. Let them do their jobs. - Collin Fultz [more]
Unread 08-01-2017, 20:47
rakosi2 rakosi2 is offline
FRC #4160
rakosi2 is an unknown quantity at this point
Muliple errors from getting started and past years code
I updated my team's laptop and eclipse is erroring. I uninstalled everything and removed eclipse and installed the newest neon eclipse following the wpi instructions.
Unread 08-01-2017, 21:26
Re: Muliple errors from getting started and past years code
Have you tried rebuilding the index? ("Rebuilding the Index" on the page linked below)
https://wpilib.screenstepslive.com/s...p-test-program
If you've already tried that, try closing Eclipse, navigating to your user home directory C:\Users\USERNAME on Windows and locate and delete the wpilib folder, then re-open Eclipse.
Unread 09-01-2017, 18:55
FRC #4160
So after deleting the wpilib folder those errors disappeared but now new errors appeared. This is the code from last year and we are using Talon SRX.
Unread 09-01-2017, 19:37
Did you install the TalonSRX library?
Unread 09-01-2017, 19:39
FRC #4160
I installed the CTRE Toolsuite v4.4.1.8.exe
Unread 11-01-2017, 00:31
FRC #4160
Since RufflesRidge asked me to delete the wpilib folder, it also deleted the SRX library. After I reinstalled CTRE Toolkit, it still did not work. What I did was copy the files from /wpilib/user/cpp over to wpilib folder and included #include "CANTalonSRX.h" at the top of the code and it started working. The code for the SmartDashboard is erroring but at least I can move the robot.
Unread 11-01-2017, 00:40
jmullins16's Avatar
jmullins16 jmullins16 is offline
AKA: Jeff Mullins
FRC #2135 (Presentation Invasion)
jmullins16 is an unknown quantity at this point
Those drives look like they are CANTalon SRX objects. The key steps to using these that are different this year are:
1) Install the CTRE tools (as you did), AND
2) add: #include <CANTalon.h> in the files so that the methods are defined. They are no longer a subset of wpilib.h as they were last year.
Also, during beta testing we did have an instance where the include paths did not quite get set up correctly for the project. Open the includes in the navigator window on the left and see if there's a path that corresponds to the CTRE files that have been installed. We think that the only time this was not set up correctly for us is when the CTRE tools were installed, but Eclipse was not restarted.
Jeff
Unread 13-01-2017, 21:13
FRC #4160
Thanks, I was able to add the SRX library but I cant add the SmartDashboard as SendableChooser is empty.
I added these and still nothing.
#include <SmartDashboard\NamedSendable.h>
#include <SmartDashboard\Sendable.h>
#include <SmartDashboard\SendableChooser.h>
#include <SmartDashboard\SendableChooserBase.h>
#include <SmartDashboard\SmartDashboard.h>
Unread 21-01-2017, 16:37
FRC #4160
Ok incase someone else has this error to fix it change
LiveWindow *lw = LiveWindow::GetInstance();
SendableChooser *chooser;
to:
frc::LiveWindow* lw = LiveWindow::GetInstance();
frc::SendableChooser<std::string> chooser;
and:
chooser = new SendableChooser();
chooser->AddDefault(autoNameDefault, (void*) &autoNameDefault);
chooser->AddObject(autoNameCustom, (void*) &autoNameCustom);
frc::SmartDashboard::PutData("Auto Modes", chooser);
to:
chooser.AddDefault(autoNameDefault, autoNameDefault);
chooser.AddObject(autoNameCustom, autoNameCustom);
frc::SmartDashboard::PutData("Auto Modes", &chooser);
