Go to Post but it was late and we were out of cardboard... - Nuttyman54 [more]
Unread 21-01-2017, 14:40
luna luna is offline
FRC #1410
luna is an unknown quantity at this point
grip errors
For the grip programming once I open the project I get an error message that says Runtime Exception and lots of text about Java.
( this is all the text)
Thread[JavaFX Application Thread,5,main] threw an exception
## Stack Trace:
```java
java.lang.RuntimeException: java.lang.reflect.InvocationTargetException
at javafx.fxml.FXMLLoader$MethodHandler.invoke(FXMLLo ader.java:1774)
at javafx.fxml.FXMLLoader$ControllerMethodEventHandle r.handle(FXMLLoader.java:1657)
at com.sun.javafx.event.CompositeEventHandler.dispatc hBubblingEvent(CompositeEventHandler.java:86)
at com.sun.javafx.event.EventHandlerManager.dispatchB ubblingEvent(EventHandlerManager.java:238)
at com.sun.javafx.event.EventHandlerManager.dispatchB ubblingEvent(EventHandlerManager.java:191)
at com.sun.javafx.event.BasicEventDispatcher.dispatch Event(BasicEventDispatcher.java:58)
at com.sun.javafx.event.EventDispatchChainImpl.dispat chEvent(EventDispatchChainImpl.java:114)
at com.sun.javafx.event.EventUtil.fireEventImpl(Event Util.java:74)
at com.sun.javafx.event.EventUtil.fireEvent(EventUtil .java:49)
at javafx.event.Event.fireEvent(Event.java:198)
at javafx.scene.control.MenuItem.fire(MenuItem.java:4 62)
at com.sun.javafx.scene.control.skin.ContextMenuConte nt$MenuItemContainer.doSelect(ContextMenuContent.j ava:1405)
at com.sun.javafx.scene.control.skin.ContextMenuConte nt$MenuItemContainer.lambda$createChildren$343(Con textMenuContent.java:1358)
at com.sun.javafx.event.CompositeEventHandler$NormalE ventHandlerRecord.handleBubblingEvent(CompositeEve ntHandler.java:218)
at com.sun.javafx.event.CompositeEventHandler.dispatc hBubblingEvent(CompositeEventHandler.java:80)
at com.sun.javafx.event.CompositeEventDispatcher.disp atchBubblingEvent(CompositeEventDispatcher.java:59 )
at com.sun.javafx.event.BasicEventDispatcher.dispatch Event(BasicEventDispatcher.java:56)
at com.sun.javafx.event.EventUtil.fireEvent(EventUtil .java:54)
at javafx.scene.Scene$MouseHandler.process(Scene.java :3757)
at javafx.scene.Scene$MouseHandler.access$1500(Scene. java:3485)
at javafx.scene.Scene.impl_processMouseEvent(Scene.ja va:1762)
at javafx.scene.Scene$ScenePeerListener.mouseEvent(Sc ene.java:2494)
at com.sun.javafx.tk.quantum.GlassViewEventHandler$Mo useEventNotification.run(GlassViewEventHandler.jav a:380)
at com.sun.javafx.tk.quantum.GlassViewEventHandler$Mo useEventNotification.run(GlassViewEventHandler.jav a:294)
at java.security.AccessController.doPrivileged(Native Method)
at com.sun.javafx.tk.quantum.GlassViewEventHandler.la mbda$handleMouseEvent$354(GlassViewEventHandler.ja va:416)
at com.sun.javafx.tk.quantum.QuantumToolkit.runWithou tRenderLock(QuantumToolkit.java:389)
at com.sun.javafx.tk.quantum.GlassViewEventHandler.ha ndleMouseEvent(GlassViewEventHandler.java:415)
at com.sun.glass.ui.View.handleMouseEvent(View.java:5 55)
at com.sun.glass.ui.View.notifyMouse(View.java:937)
at com.sun.glass.ui.win.WinApplication._runLoop(Nativ e Method)
at com.sun.glass.ui.win.WinApplication.lambda$null$14 8(WinApplication.java:191)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Nativ e Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Native MethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(De legatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at sun.reflect.misc.Trampoline.invoke(MethodUtil.java :71)
at sun.reflect.GeneratedMethodAccessor1.invoke(Unknow n Source)
at sun.reflect.misc.MethodUtil.invoke(MethodUtil.java :275)
at javafx.fxml.FXMLLoader$MethodHandler.invoke(FXMLLo ader.java:1771)
... 43 more
Caused by: com.thoughtworks.xstream.converters.ConversionExce ption: Error deserializing source
---- Debugging information ----
message : Error deserializing source
cause-exception : java.lang.RuntimeException
cause-message : src\matrix.cpp:411: error: (-215) u != 0 in function cv::Mat::create
class : edu.wpi.grip.core.sources.ImageFileSource
required-type : edu.wpi.grip.core.sources.ImageFileSource
converter-type : edu.wpi.grip.core.serialization.SourceConverter
line number : 32
class[1] : java.util.ArrayList
converter-type[1] : com.thoughtworks.xstream.converters.collections.Co llectionConverter
class[2] : edu.wpi.grip.core.Pipeline
converter-type[2] : com.thoughtworks.xstream.converters.reflection.Ref lectionConverter
version : 1.5.0-rc2
at edu.wpi.grip.core.serialization.SourceConverter.un marshal(SourceConverter.java:69)
at com.thoughtworks.xstream.core.TreeUnmarshaller.con vert(TreeUnmarshaller.java:72)
at com.thoughtworks.xstream.core.TreeUnmarshaller.con vertAnother(TreeUnmarshaller.java:66)
at com.thoughtworks.xstream.core.TreeUnmarshaller.con vertAnother(TreeUnmarshaller.java:50)
at com.thoughtworks.xstream.converters.collections.Ab stractCollectionConverter.readItem(AbstractCollect ionConverter.java:73)
at com.thoughtworks.xstream.converters.collections.Co llectionConverter.addCurrentElementToCollection(Co llectionConverter.java:98)
at com.thoughtworks.xstream.converters.collections.Co llectionConverter.populateCollection(CollectionCon verter.java:91)
at com.thoughtworks.xstream.converters.collections.Co llectionConverter.populateCollection(CollectionCon verter.java:85)
at com.thoughtworks.xstream.converters.collections.Co llectionConverter.unmarshal(CollectionConverter.ja va:80)
at com.thoughtworks.xstream.converters.reflection.Abs tractReflectionConverter.unmarshallField(AbstractR eflectionConverter.java:503)
at com.thoughtworks.xstream.converters.reflection.Abs tractReflectionConverter.doUnmarshal(AbstractRefle ctionConverter.java:429)
at com.thoughtworks.xstream.converters.reflection.Abs tractReflectionConverter.unmarshal(AbstractReflect ionConverter.java:281)
at com.thoughtworks.xstream.core.TreeUnmarshaller.sta rt(TreeUnmarshaller.java:134)
at com.thoughtworks.xstream.core.AbstractTreeMarshall ingStrategy.unmarshal(AbstractTreeMarshallingStrat egy.java:32)
at com.thoughtworks.xstream.XStream.unmarshal(XStream .java:1230)
at com.thoughtworks.xstream.XStream.unmarshal(XStream .java:1214)
at com.thoughtworks.xstream.XStream.fromXML(XStream.j ava:1085)
at edu.wpi.grip.core.serialization.Project.open(Proje ct.java:115)
at edu.wpi.grip.core.serialization.Project.open(Proje ct.java:94)
at edu.wpi.grip.ui.MainWindowController.openProject(M ainWindowController.java:168)
... 53 more
Caused by: java.lang.RuntimeException: src\matrix.cpp:411: error: (-215) u != 0 in function cv::Mat::create
at org.bytedeco.javacpp.opencv_core$Mat.copyTo(Native Method)
at edu.wpi.grip.core.util.ImageLoadingUtility.loadIma ge(ImageLoadingUtility.java:33)
at edu.wpi.grip.core.sources.ImageFileSource.loadImag e(ImageFileSource.java:123)
at edu.wpi.grip.core.sources.ImageFileSource.loadImag e(ImageFileSource.java:119)
at edu.wpi.grip.core.sources.ImageFileSource.initiali ze(ImageFileSource.java:85)
at edu.wpi.grip.core.Source.initializeSafely(Source.j ava:94)
at edu.wpi.grip.core.serialization.SourceConverter.un marshal(SourceConverter.java:65)
... 77 more
## System Info:
Property Name | Property
GRIP Version | 1.5.0-rc2
java.version | 1.8.0_92
javafx.version | 8.0.92
os.name | Windows 10
os.version | 10.0
os.arch | x86
Unread 21-01-2017, 16:58
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Re: grip errors
Please open an issue on our github page
WPILib
GRIP, RobotBuilder
