Go to Post JVN, thanks for working with me. You will make a great MC anywhere. Folks, he actually loosened up and fit right in. - Steve W [more]
  #46   Spotlight this post!
Unread 21-01-2017, 12:29
bowmanb bowmanb is offline
AKA: Bruce Bowman
FRC #3991 (KnightVision)
bowmanb is an unknown quantity at this point
Re: Is the Boiler worth it?
If we have an opponent that is a hopper loader/high shooter, our first move in tele will be to run around and dump all the hoppers. Ball pit time! It will be the extremely rare robot that can process balls from the floor fast enough to be effective.
  #47   Spotlight this post!
Unread 21-01-2017, 12:34
novelCytologist novelCytologist is offline
FRC #2197
novelCytologist is an unknown quantity at this point
My team says it's worth it, but I can't see how. You'd need an extremely quick shooter and accuracy is critical. Even slightly off, and your robot sucks.
And retrieval time is just too long. It'd be more worth it if balls were worth more points.
However, we also have to consider that if all robots focus on gears, maxing the rotors may end up the norm, and boilers are now the only way to get ahead.
  #48   Spotlight this post!
Unread 21-01-2017, 13:04
[citation needed]
Sorry, but from what I've seen in the past, if floor loading is available, there'll be a lot of teams that can be extremely lethal with it, especially when there's no capacity limit other than robot size. '09 and '06 come to mind.
  #49   Spotlight this post!
Unread 21-01-2017, 17:12
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
You are forgetting about collecting fuel from the floor while doing gear cycles...
My time in FIRST has made me a better person, frankly I don't know where I'd be without it.
2011 Lake Superior Regional Champs (Thanks 2512 & 3747)
2015 Central Illinois Regional Engineering Inspiration Award recipients
2016 Central Illinois Regional Champs (Thanks 2481 & 2220)
  #50   Spotlight this post!
Unread 21-01-2017, 17:21
NShep98's Avatar
NShep98 NShep98 is offline
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud of
Originally Posted by KelleyCook View Post
But this raises another question, is it 5/second for each boiler or combined?
Per the field tour video, it is 5 fuel per second for each goal.
Per the manual, however, this is an average value, depending on how tightly packed the goal is, so theoretically it could be processed faster than this.
FRC 2079 - 4H ALARM Robotics 2015 - 2017
FLL 2011, 2013
  #51   Spotlight this post!
Unread 21-01-2017, 17:24
pmattin5459's Avatar
pmattin5459 pmattin5459 is offline
AKA: Patrick Mattin
FRC #5459 (Ipswich TIGERS)
Rookie Year: 2015
pmattin5459 will become famous soon enoughpmattin5459 will become famous soon enough
You lose a couple of cycles while shooting the balls you're collecting. If you do such a strat, you can only get maybe two rotors on your own. It's better to either shoot the entire match (and be sure to hit that 40kpa) and then gear rather than pursuing a hybrid strat that may or may not get you both 2/3 rotors turning and 40kpa. Especially if one of your alliance partners can hit 6-8 gears on their own.
  #52   Spotlight this post!
Unread 21-01-2017, 18:38
Green Potato Green Potato is online now
AKA: Tory Farmer
FRC #0422 (Mech Tech Dragons)
Team Role: Tactician
Green Potato is a glorious beacon of lightGreen Potato is a glorious beacon of lightGreen Potato is a glorious beacon of lightGreen Potato is a glorious beacon of lightGreen Potato is a glorious beacon of light
It's important to note that not all matches will be close: if you think a qualification match is going to be a blowout,getting that extra RP will be very valuable.
This also means that the best partners in qualms arn't necessarily the best ones for elims... which is going to be fun.
Everything that can go wrong WILL go wrong, except the things we expect to go wrong and actually plan for.
  #53   Spotlight this post!
Unread 21-01-2017, 19:18
Skyehawk's Avatar
Nuts N' Bolts
AKA: Skye Leake
You may be significantly underestimating the speed at which some teams will release a torrent of balls on the high goal... The time spent shooting for some teams will be less than 5 seconds for 50 balls. I'll let you draw your own conclusions on how a match like this will play out when they have a collector that can fill up their hopper once every gear cycle or two.
Edit: And yes, there will be a team somewhere that does everything well. 7 gear cycles, 150 balls scored in the high goal, climb, all by themselves.
  #54   Spotlight this post!
Unread 21-01-2017, 19:26
AKA: Patrick Mattin
Rookie Year: 2015
That's 10 balls/sec. Not sure if achievable, but I'm guessing the average may be more around 5-7 balls/sec.
Also, add a second or two for alignment. Add 10 seconds if there's any defense at all on you. You're looking at spending a minute or so on shooting, giving you time to cycle maybe 3-4 gears. That is a lot better than a plain gear cycler, so I will admit for a team that can hit those fast, accurate shooting goals (as Dr. Joe said) it's a viable strat... if you're alone. If you have a couple of gearbots on your alliance, you shouldn't bother cycling back and forth and just collect close to the goal and shoot fast.
Edit: Not sure how timing would work for 7 gear cycles, 150 pts, and climbing. It might happen, but I wouldn't bet on it.
  #55   Spotlight this post!
Unread 21-01-2017, 19:44
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
If you're good enough to score 7 balls per second, you're good enough not to have most defense (much less any defense at all) waste 10 seconds of your life for every load you shoot. People way over estimate the actual in-match effects of most--and even some rare top tier--defensive play versus powerhouse offensive robots.
  #56   Spotlight this post!
Unread 21-01-2017, 19:49
Skyehawk's Avatar
Nuts N' Bolts
AKA: Skye Leake
I didn't do any timing or math, I just wanted to put out an extreme example. Something that may be seen with a super-bot paired with 2 bots keeping defense from happening on said super-bot. And a fair bit of luck with game pieces in the right locations/clusters. Also don't forget about teams that may have an insane autonomous (WAVE Robotics in 2015 comes to mind).
  #57   Spotlight this post!
Unread 21-01-2017, 20:08
AKA: Patrick Mattin
Rookie Year: 2015
I could see gear+40kpa auton happening, like 2 ball last year. If there were such a super-bot, it would end up 1st seed and pick a gear cycler or a bot like itself, then a defense bot to round out the alliance.
  #58   Spotlight this post!
Unread 21-01-2017, 20:26
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
I didn't do any timing or math, ...
Oh, but you should! It's fun!
Richard Wallace
since 2003
  #59   Spotlight this post!
Unread 23-01-2017, 07:29
RoboRebels5988 RoboRebels5988 is offline
FRC #5988
RoboRebels5988 is an unknown quantity at this point
We are a 2nd year, FRC team with very little experience, we are currently thinking our best bet is to focus on a simple mechanism to deliver cogs, rather that a fuel retrieval and shooting system...what would others advise? We appreciate your thoughts. Thanks.
  #60   Spotlight this post!
Unread 23-01-2017, 08:04
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Actually, I read this the other way. Assuming that the indexer for this counter is of the "gumball machine" style (as seen in some of the kickoff home videos), it will run more slowly with only a few fuel, because some of the holes will be empty as they feed to the counter.
For this you'd be better off looking for threads that talk about gears than one that talks about fuel. Don't be afraid to use the search function! Bottom line: yes, this appears to be a common, and likely relatively effective, solution for low resource/experience teams. This means that in order to stand out as a gearbot, you will want to be able to hang a LOT of GEARS during the match period; two or three probably won't get you picked second except at the smaller district events.
