Go to Post Im very proud of my kids, and my whole team, the passion and emotion here is what FIRST is all about :) - Kims Robot [more]
Unread 21-01-2017, 16:30
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
Versa Planetary v2 (3:1) Planet Gear Seizing
Has anyone else had any problems with any of the planet gears from their Versa Planetary v2 transmissions seizing up in the middle of running a motor?
This has happened twice this week on seperate shooter prototype desings. One had two 4" Colsons on a shaft, and the other had eight 4" colsons on the shaft. Both were using 775 pros.
We ran the wheels at the speed we wanted multiple times to test shooting consistency with the PID, and after a while, the wheel completely locked up while the wheel is in motion and causes a sudden stop.
Both times this has happened, we opened the transmissions and found that exactly one of the planet gears got completely stuck on its pinion and we cannot get it unstuck. This has only happened on 3:1 v2 transmissions so far.
We're wondering if this is a manufacturing flaw that isn't just happening to us.
Unread 21-01-2017, 17:02
jeremylee's Avatar
jeremylee jeremylee is offline
FRC #2526 (Crimson Robotics)
jeremylee is a jewel in the roughjeremylee is a jewel in the roughjeremylee is a jewel in the rough
Re: Versa Planetary v2 (3:1) Planet Gear Seizing
I just swapped a 3:1 today with same issue, one gear stuck. We didn't even get any runtime on it. Hope we don't have anymore issues...
Unread 21-01-2017, 17:10
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
I haven't used 3:1 this year, but I have a few questions/suggestions. Did you properly grease the gearboxes? Did you support the shaft well (i.e. no radial load on the shaft)? Was there any axial load away from the VP? I have heard that all three of these can cause failures.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 21-01-2017, 17:14
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Also when were the 3:1 stages purchased.
Unread 21-01-2017, 17:21
jeremylee's Avatar
Pre-grease only. Tried to spin from power supply to break in the motors, pulled way too much power for a single stage. Tried to spin by hand, knew something wasn't right. Found one planet siezed. Swapped in another 3:1 and it's much smoother, but we haven't put any load on it yet. Recently purchased after kickoff.
Last edited by jeremylee : 21-01-2017 at 17:28. Reason: Added when they were purchased.
Unread 21-01-2017, 17:54
lorykzarr's Avatar
lorykzarr lorykzarr is offline
AKA: Theo Camilleri
FRC #0854 (Iron Bears)
lorykzarr is on a distinguished road
We've been having some issues with VersaPlanteries this year. What fixed most of the binding was taking 2 planet gears and flipping them over then reinstalling them. That and letting the gearboxes burn in at a low speed for a few minutes.
Unread 21-01-2017, 19:36
Chris is me's Avatar
AKA: Pinecone
The planet gears should be the same between the V1 and V2 models. Just the case / mounting changed.
Could you post pictures of your seized planet stage?
Unread 21-01-2017, 19:45
Crew Cox's Avatar
Crew Cox Crew Cox is offline
Electrical team Captain
FRC #5546 (A.R.T)
Team Role: Driver
Crew Cox is a jewel in the roughCrew Cox is a jewel in the roughCrew Cox is a jewel in the rough
Also I'd suggest (if you haven't already) grease the shafts that planet gears themselves spin on instead of just where the gears mesh.
The gear's may be generating heat, swelling, and seizing up.
Unread 21-01-2017, 19:53
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
We are running the same 3:1 ratio in the v1 gearboxs with 775 pros without issue, we used the very same gearboxes all 2016 season(5 competitions) with regular 775's and only had one set screw come loose other than that no problems, we haven't bought any of the V2 versaplanterary's yet
EDIT: we did grease them heavily
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 21-01-2017, 19:56
RoboChair's Avatar
AKA: Devin Castellucci
MORE LUBE!!!!!
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 21-01-2017, 20:05
rbiguy12 rbiguy12 is offline
FRC #2062 (CORE)
rbiguy12 is an unknown quantity at this point
Check that the pins on the carrier plate haven't moved. We had trouble with them popping out slightly and seizing in 2015 and ended up having to weld them in (Pretty sure VexPro suggested this when we contacted them). We used the v1's, but the v2's still don't have welded pins.
This was under pretty high torque though, which it sounds like yours aren't. Just a suggestion.
Unread 21-01-2017, 20:50
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
This was an issue we had last year as well, but we were also pushing their load limits. After speaking with several teams at worlds, and JVN, the most common recommendation was to weld the carrier plate pins so they couldn't slide out of the plate.
Unread 21-01-2017, 21:51
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Built a few planetary gear boxes today and the motor plate was so tight and seemed to force the shaft off center. Runhinged them at full speed for a little while helped. So did extra lithium grease.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 21-01-2017, 22:09
bkahl's Avatar
bkahl bkahl is offline
Make Champs Great Again
AKA: Bailey Kahl
FRC #0125 (NUTRONS)
bkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond reputebkahl has a reputation beyond repute
We experienced similar issues today. BRAND NEW 3:1 stage.
1x775 into a 3:1, single stage VP.
Just as you are describing, a single planet began to seize on its pin. The seized planet was even swapped for used planet gear from 2016 with the exact same results. The transmission almost immediately began to seize from the same pin.
The gearbox was reassembled multiple times by different people and was properly greased. Maybe it's time to explore needle bearings...
Team 125
College Student/Whatever Brando says
Team 195
Alumni
Facebook
EWCP
Unread 21-01-2017, 22:24
MoistRobot's Avatar
MoistRobot MoistRobot is offline
AKA: Jon Charboneau
FRC #0832 (OSCAR)
MoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of light
We're running a pair 775 pros through a Versaplanetary v2 3:1 reduction for a week or so now and have had no problem with it.
