Go to Post work? I can't remember when the last time i did that was... - Carolyn Duncan [more]
  #31   Spotlight this post!
Unread 20-01-2017, 14:48
Bob Steele's Avatar
AKA: Bob Steele
Re: Polycarbonate/Plexiglass Ruling
Waterjets cut all of these materials pretty well with no fumes.
  #32   Spotlight this post!
Unread 20-01-2017, 14:54
Oblarg Oblarg is offline
AKA: Eli Barnett
When convenient, affordable desktop waterjets exist, I'll look into them for sure.
"The breakfast of champions!"
  #33   Spotlight this post!
Unread 20-01-2017, 16:45
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
they are now in the $5000 range. https://www.wazer.com/
It was really nice to work for a waterjet maker back when I was on 1318. our 2009 robot was made all of waterjet polycarbonate sheet (which was recylced from a building demolition!)
Our 2008 robot had a waterjet 1/4" titanium sheet as the only frame element. everything just bolted right to it. it also has infinite rotation swerve drives using waterjet copper sheet for custom slop rings.
  #34   Spotlight this post!
Unread 20-01-2017, 18:33
frcguy's Avatar
frcguy frcguy is offline
#GearsAllDay
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Originally Posted by Cory View Post
My opinion is that the Wazer is absolutely useless for FRC purposes (but cool as a technology demonstration).
It cuts REALLY slowly, the cutting area isn't large enough for more than a few small parts, the cost to run it is high, and accuracy will be questionable compared to an industrial water jet. Maintenance will likely add up to more than the cost of the machine within a few years depending on how much its used.
You'd get a lot more mileage out of paying for $5000 (plus cost of consumables) of waterjetting from a legit vendor.
A legitimate water jet cutter is going to be $100-200k depending on how it's optioned out, plus a minimum of $45/hr (up to $60+/hr) to run in power/abrasive/water/amortized maintenance. They are very finnicky and constantly have little problems that pop up that require you to stop and clean things out or perform minor fixes. When the pumps reach their service intervals you're looking at a multi-thousand dollar rebuild. The mixing tubes/orifices are not cheap either and need somewhat frequent replacement. These are also enormously loud and messy machines. Glenn can speak more to his experience with ownership of one, but it would take a unique set of circumstances for a team to have a shop that is suited to owning one.
Legitimate metal cutting lasers for FRC use (1/4" aluminum) are so expensive they're not even worth discussing. $200k-400k. Huge power requirements, though much cheaper to run than water jet due to fewer consumables and lower maintenance costs. These are machines designed to cut 4'x12' sheets all day long as fast as possible and people who own them have to run the machine virtually nonstop, often for multiple shifts a day to make any money off them. Just totally in a whole other world than FRC usage,
Not sure about the Wazer.
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
  #35   Spotlight this post!
Unread 20-01-2017, 18:58
JohnFogarty's Avatar
AKA: @doctorfogarty
From the short amount of research I did. It takes about $5000 to get 1 ipm of cutting speed for waterjet machines using 1/4" aluminum as a baseline material.
John Fogarty
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632, FRC 4901
  #36   Spotlight this post!
Unread 21-01-2017, 22:54
engunneer's Avatar
AKA: Branden Gunn
FRC #4761
and to compare to industrial level waterjets, a 60ksi jet can cut 1/4" Aluminum at 22 inches per minute with a nice cut, and ~55 ipm if you tear through it at max speed and don't care about the cut.
  #37   Spotlight this post!
Unread 21-01-2017, 23:25
dmaggio744's Avatar
dmaggio744 dmaggio744 is offline
Steely Eyed Missile Man
AKA: Drew Maggio
FRC #2869 (Regal Eagles)
Rookie Year: 2015
dmaggio744 is on a distinguished road
As exciting as waterjets are, my team has found huge success with desktop CNC routers. They are relatively cheap, relatively intuitive to use, and cut softer materials like wood and polycarb very easily, and are advertised to cut aluminum if you know what your doing.
We use a Shapeoko 3 XL with DeWalt Router and it's become our new favorite tool. It has a build volume of 33" by 17", and comes with very easy to use software. Our XL version is about $1,600, abut you can scale up(XXL 33" by 33") or down(Standard 16" by 16"). Feel free to pm me if your skeptical, on the fence about buying one, or just want to know more!
  #38   Spotlight this post!
Unread 24-01-2017, 11:27
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Originally Posted by FrankJ View Post
One easy test to tell acrylic from poly. Hit a piece hard against a table top. If it cracks or shatters it is probably acrylic. Wear your safety glasses. So in the robot world. Lexan=polycarbonate=good. Plexiglass=acrylic=bad.
The test I was taught (not sure how accurate) is to look into the cross section. If it's clear, it's acrylic. If it's dark, it's polycarbonate.
I have also done an experiment for a non-FRC related group of kids. I took two identically sized pieces of polycarbonate and acrylic plastic (about 2" by 12"). (Fun note: polycarbonate is easy to cut with woodworking power tools like miter saws. Acrylic, I scored with a knife and snapped.)
To the eye, other than the cross section, both pieces look very similar. Then I folded the polycarbonate in half like a sheet of paper. You end up with a nice 90-degree bend. Then I tried the same with the acrylic, and it shatters into pieces (wear gloves). Insert your favourite object lesson here about things looking the same but being very different inside, don't judge inward strength by outward appearances, looking OK on the outside but handling stress and pressure very differently on the inside, etc.
"If I'm going to mentor someone, I'm going to be involved in their life as a positive force." -Mechvet
  #39   Spotlight this post!
Unread 24-01-2017, 12:04
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
I have not heard that. It might be possible. They have different optical properties. Acrylic is "brighter". It might be something that a person regularly working with both can judge. I would be hesitant using that criteria as a relatively non expert.
