Go to Post EVERYONE on the team is offered the same opportunities to be a team player, it is up to each person to step up and play the game. - MariaCastro [more]
Unread 21-01-2017, 19:03
zDrakon zDrakon is offline
FRC #3501
zDrakon is an unknown quantity at this point
Arduino & Roborio cant find each other I2C Issues
code: http://pastebin.com/9uq4S2dQ
Okay, so I'm trying to scan through all the possible addresses that the arduino could be from both Roborio (our code here) and Arduino (Arduino used I2C scanner code: http://playground.arduino.cc/Main/I2cScanner)
We have verified the wiring of the arduino is correctly wired with A4 and A5 connected to the I2C and ground and power to the I2C port of roborio.
Both devices can't find each other.
Anyone have a solution to make both devices find each other?
(Strangely enough we can have Roborio send data to Arduino and Arduino read it but the Arduino can't successfully send data to the roborio with the Roborio giving a response like a System.out.println() in the DriverStation console)
Unread 21-01-2017, 22:16
Re: Arduino & Roborio cant find each other I2C Issues
Is your arduino configured as a slave?
Unread 21-01-2017, 22:40
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Congrats, you've correctly set up the Arduino as a slave 🎉
In I2C, slaves can only send data for a transaction, not any time they want. For Arduino, that means you can only write in the onRequest handler function, and only the number of bytes the master expects. On the roboRIO side, you need to call I2C.transaction()
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 21-01-2017, 23:56
avayner avayner is offline
FRC #3501
avayner is an unknown quantity at this point
We've done exactly that, but for some reason onRequest was not being triggered... Any ideas how to troubleshoot this?
Unread 22-01-2017, 00:47
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
Could you post the code you're using (roborio and arduino)?
Unread 22-01-2017, 01:47
FRC #3501
Roborio code: http://pastebin.com/TiFcYq6L
Arduino: http://pastebin.com/TDPk9W5i
Do keep in mind we did try using onREquest for arduino and set it up as a slave prior but for some reason it didnt work. My team is confused, even the mentor is having trouble explaining what's happening.
Unread 22-01-2017, 15:55
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
I see. Try this
roboRIO:
static I2C arduino = new I2C(Port.kOnboard, 42);
@Override
public void teleopPeriodic() {
    byte[] sendData = "sample text".getBytes();
    byte[] receiveData = new byte[sendData.length];
    boolean failed = arduino.transaction(sendData, sendData.length, receiveData, receiveData.length);
    if(!failed) {
        System.out.println("Got data: " + new String(receiveData, 0, receiveData.length);
Arduino:
#include <Wire.h>
void setup() {
  Wire.begin(42);
  Wire.onRequest(requestEvent);
  Serial.begin(9600);
void loop() {
  delay(100);
// send back the same data as we receive
void requestEvent() {
  Serial.println("Got request:");
  while (Wire.available()) {
    char c = Wire.read();
    Serial.print(c);
    Wire.write(c);
Unread 27-01-2017, 22:52
Harp Harp is offline
FRC #3501
Harp is an unknown quantity at this point
The Arduino didn't read anything from the roborio using this code. We've since switched to using a raspberry pi
