Go to Post We had an over all losing record this year. When I look at kid's faces, they don't give a rip about that. I see excitement about the next event and talking about improvements for next year. Winning is nice, but that is not the reason I do what I do. - wilsonmw04 [more]
Unread 21-01-2017, 20:40
berkleyfanatic's Avatar
berkleyfanatic berkleyfanatic is offline
FRC #0247 (Da Bears)
berkleyfanatic is an unknown quantity at this point
Re: Mecanum Drive control
In 2015 my team used encoders and a gyro for mecnuam and I'm pretty sure it worked out good for us
Unread 21-01-2017, 21:01
AriMindell AriMindell is offline
FRC #1389 (The Body Electric)
Rookie Year: 2015
AriMindell will become famous soon enoughAriMindell will become famous soon enough
Tyler,
Some of the things you wrote are still a bit ambiguous to me. I think it would be enlightening to discuss it further. Would you be interested in doing that? I don't want to pester you if you don't want to do that.
I, for one, would love to see that discussion
Unread 22-01-2017, 00:26
OK, I'll kick it off with this.
If you make certain simplifying assumptions (which under certain adverse conditions may not be too realistic; more on this if there is interest), mecanum wheels do not "slip" unless they are torqued so hard that they lose traction. And yes, they lose traction more easily than normal wheels because of the nature of the reaction forces between the floor and the rollers.
Under these assumptions, the rollers are rolling, not slipping. The rolling of the rollers is what makes mecanum do what it does.
The computation to turn a driver command of a simultaneous combination of forward/reverse plus strafe_right/left plus rotate_CW/CCW into four wheel speeds is called inverse kinematics. The four wheel speeds resulting from this computation will cause the desired robot motion, if the resulting reaction forces between the roller and floor are less than the available traction so that the rollers roll without slipping.
On the other hand, taking 4 instantaneous measured wheel speeds (one for each wheel) and turning them into the corresponding instantaneous robot motion (forward/reverse plus strafe_right/left plus rotate_CW/CCW) is called forward kinematics.
If the rollers are not slipping, it is possible to do the forward kinematic computation. And in theory, you could integrate the resulting instantaneous robot motion over time to find the robot position and heading. I do not know if any teams have done this with a fruitful degree of success.
Unread 22-01-2017, 01:06
Oblarg Oblarg is offline
AKA: Eli Barnett
I could be wrong, but I believe he's suggesting that mecanum rollers are prone to "sticking" and not rolling freely (this would be consistent with my experience of certain brands/models of mecanum wheel). Under these conditions, the wheels of a strafing mecanum robot could be said to "slip," and throw off the correspondence between encoder readings and movement.
"The breakfast of champions!"
Unread 22-01-2017, 01:16
TylerHarmon's Avatar
TylerHarmon TylerHarmon is offline
TylerHarmon is an unknown quantity at this point
Hi Tyler,
Thank you for taking the time to respond to my question.
Sure, if you want to discuss it further we can. My main point is that the rollers on mecanum wheels...
... freely spin, which allows a robot to strafe, but results in inconsistent data when used with an encoder.
Unread 22-01-2017, 11:01
Rookie Year: 2015
Ether posted the following code for determining robot position based on the wheel velocities of mecanum wheels in another thread:
FWD = r*(w1+w2+w3+w4)/4
STR = r*(w1-w2+w3-w4)/4
Wv  = (1/k)*(w1+w2-w3-w4)/4
r is wheel radius
k is |trackwidth/2| + |wheelbase/2|
w1,w2,w3,w4 are FL,BL,BR,&FR wheel speeds in rads/sec
Wv is robot clockwise rotation rate in radians per second
The implicit assumption is that the velocity vector applied to the robot by a mecanum wheel spinning at constant velocity is constant.
are you arguing that the velocity vector created by a mecanum wheel spinning at a constant velocity is not constant or predictable, therefore that equation provides an unreliable estimate of robot position?
Unread 22-01-2017, 21:32
r is wheel radius
I understand all of this logic, but it just doesn't work in practice. You simply cannot achieve the precision of tank drive with mecanum wheels because the rollers on mecanum wheels sometimes spin and sometimes do not. In other words, there is a large amount of slop in the system that cannot be removed with programming.
If you show me an example of you consistently driving a set distance and/or turning a certain amount without a gyroscope, only with encoders then I will accept that mecanums can be well controlled with encoders. However, based on the mechanical nature of mecanum wheels, such motion cannot practically be controlled.
Unread 22-01-2017, 21:36
Yes, that is what I'm saying. The force vectors are not reliable in practice, only in theory. The variable "rolling" of the rollers causes this effect. Because those force vectors change (not only in magnitude, but also in direction) you simply cannot achieve precise motion control of a robot running on mecanums.
