Re: URL for MjpegServer from CameraServer/USB Camera
Yeah any additional cameras will just increase the port number, so cam 2 will use 1182, cam 3 will use 1183 etc...
Thanks! Didn't get a chance to test until today (building was closed for bad weather) but it worked really nicely. One (hopefully) last question: is there any way to increase the resolution of the mjpg stream? Currently GRIP shows the stream as a tiny thumbnail which is workable but a little annoying.
Thanks! Didn't know that the USBCamera object affected the stream like that. Good to know.
What would the mjpegserver be if I am accessing the camera from a raspberry pi? Currently I am just typing raspberrypi.local:1185 into a browser to see the camera image but I would like to get it to appear on my smartdashboard.
Oh wait...it should be the same thing just port 1185, I'll give that a go and relay how it goes.
#7
Any success? I am on the same boat as you are currently.
#8
I would also like to know how to get the camera stream from the raspberry pi on the dashboard. Even better would be an unmodified Labview Dashboard, as nobody on my team is interested in using the other options. I'm fairly certain it is possible with the right things published to network tables, but who knows...
#9
Well, I'm upset...I hit submit post and it just went *poof*...anyway a rundown of my current situation is that it didn't work however I an idea that I just thought of which I will test tomorrow (and paste my code). I believe I have just been making a stupid mistake. As for MuskieProgrammes question, I would use the SmartDashboard definitely because I believe LabView can only handle Usbcameras, could be wrong though. Also, network tables can only publish/get variables (again, 99% positive).
Ryan |
#10
Yes, the actual stream can't be over network tables. But if you start reading the CameraServer class you find it is publishing certain information to NetworkTables... I believe the LabView dashboard uses this information to provide the camera drop-downs. It looks like all of CameraServer's dependencies are available on the Pi so I'm going to try to deploy it there and see what happens.
