Go to Post The robots are the attracting force, the common interest that brings us all together - sanddrag [more]
Unread 21-01-2017, 17:11
dmelcer9 dmelcer9 is offline
AKA: Daniel
FRC #0810 (Mechanical Bulls)
dmelcer9 is an unknown quantity at this point
URL for MjpegServer from CameraServer/USB Camera
I'm looking to use a USB camera connected to the robot for GRIP development. I know that GRIP doesn't accept the dashboard stream, but the MJPG stream supposedly works. However, I can't figure out what URL to point GRIP to if I want to actually use the stream.
Currently, our code looks something like this (forgot to commit to github so don't have the exact code):
//Robot.java -> RobotInit
UsbCamera c = CameraServer.getInstance().startAutomaticCapture();
MjpegServer s = CameraServer.getInstance().addServer("gripStream");
s.setSource(c);
What URL would I point the "Add IP Camera" source to in GRIP to get the camera to work properly?
Unread 22-01-2017, 00:07
Thad House Thad House is online now
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Re: URL for MjpegServer from CameraServer/USB Camera
s.setSource(c);
You actually don't need that MjpegServer definition or the setSource line. startAutomaticCapture will automatically create the stream.
The way to access the code from GRIP would be
http://roborio-TEAM-frc.local:1181/?action=stream
Team 4488 - Mentor 2013-2016
Unread 22-01-2017, 00:18
AKA: Daniel
Really? Thank you! I'm guessing any additional streams (for example if we have 2 cameras) would use port 1182? I saw some sort of reference to using the next available port.
Unread 22-01-2017, 01:38
Yeah any additional cameras will just increase the port number, so cam 2 will use 1182, cam 3 will use 1183 etc...
Unread 24-01-2017, 22:01
AKA: Daniel
Thanks! Didn't get a chance to test until today (building was closed for bad weather) but it worked really nicely. One (hopefully) last question: is there any way to increase the resolution of the mjpg stream? Currently GRIP shows the stream as a tiny thumbnail which is workable but a little annoying.
Unread 24-01-2017, 22:39
When you call startAutomaticCapture, it will return a UsbCamera object. Call setResolution on that object, and that will set the resolution to whatever you put in.
Unread 24-01-2017, 22:41
AKA: Daniel
Thanks! Didn't know that the USBCamera object affected the stream like that. Good to know.
Unread 25-01-2017, 07:40
ryan.mitchell ryan.mitchell is offline
FRC #1512 (Big Red)
Rookie Year: 2015
ryan.mitchell is an unknown quantity at this point
What would the mjpegserver be if I am accessing the camera from a raspberry pi? Currently I am just typing raspberrypi.local:1185 into a browser to see the camera image but I would like to get it to appear on my smartdashboard.
Unread 25-01-2017, 08:29
FRC #1512 (Big Red)
Rookie Year: 2015
Oh wait...it should be the same thing just port 1185, I'll give that a go and relay how it goes.
Unread 01-02-2017, 21:50
thecoopster20 thecoopster20 is offline
4th Year Programmer - Java
FRC #3602 (Robomos)
thecoopster20 is an unknown quantity at this point
Any success? I am on the same boat as you are currently.
Unread 01-02-2017, 22:34
MuskieProgramme MuskieProgramme is offline
FRC #6420
MuskieProgramme is an unknown quantity at this point
I would also like to know how to get the camera stream from the raspberry pi on the dashboard. Even better would be an unmodified Labview Dashboard, as nobody on my team is interested in using the other options. I'm fairly certain it is possible with the right things published to network tables, but who knows...
Unread 01-02-2017, 23:12
FRC #1512 (Big Red)
Rookie Year: 2015
Well, I'm upset...I hit submit post and it just went *poof*...anyway a rundown of my current situation is that it didn't work however I an idea that I just thought of which I will test tomorrow (and paste my code). I believe I have just been making a stupid mistake. As for MuskieProgrammes question, I would use the SmartDashboard definitely because I believe LabView can only handle Usbcameras, could be wrong though. Also, network tables can only publish/get variables (again, 99% positive).
Ryan
Unread 02-02-2017, 09:15
FRC #6420
Yes, the actual stream can't be over network tables. But if you start reading the CameraServer class you find it is publishing certain information to NetworkTables... I believe the LabView dashboard uses this information to provide the camera drop-downs. It looks like all of CameraServer's dependencies are available on the Pi so I'm going to try to deploy it there and see what happens.
