Go to Post "Friends don't let friends build mecanum" - Michael Corsetto [more]
Unread 22-01-2017, 12:19
bdaroz's Avatar
bdaroz bdaroz is offline
Programming Mentor
AKA: Brian Rozmierski
FRC #5881 (TVHS Dragons)
Rookie Year: 2016
bdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud of
Re: Versa Planetary v2 (3:1) Planet Gear Seizing
Somewhat on-topic here...
A question for the collective knowledge pool:
How much lithium grease is too much / how much is too little?
(Keeping in mind the v2 manual uses the term "liberal" -- some students will want to drown the gearbox, others will go the opposite route.)
We had a borrowed VP last year that was pre-greased (rookie year) and went out and invested in several this year, so we're looking to do it right.
Unread 22-01-2017, 16:44
Chris is me's Avatar
AKA: Pinecone
A good rule of thumb is to put on as much as you think you need, and then a little bit more than that.
I like to paint the grease onto the outer edges of the planet gears and spin it around, then add more and spin, etc until every surface has some visible grease on it. Then a touch more and assemble it.
It's not that easy to over-grease a gearbox.
