Go to Post Wisdom shared is priceless, isn't it? And timeless. - JaneYoung [more]
Unread 22-01-2017, 13:40
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Re: Programming Bulletin 873M Ultrasonic Analog Sensor
Originally Posted by efoote868 View Post
Were you able to read any voltage from the sensor? Do you have a voltmeter to debug the circuit?
On the introduction page:
http://www.ab.com/en/epub/catalogs/1...roduction.html
The red LED only flashes in teach mode, otherwise it is off. What were you doing with the white wire?
We tested it wrong, now that I see the wiring diagram. We thought the white was the common for the analog output. We wired the resistors between white and black, now I see we should have done, black and blue.
Will test again on Monday and Post results, and what values of resistors we used for divider.
The sooner we get behind schedule, the more time we have to catch up.
