CANTalon w/Encoder DriveStraight Command example
Hi,
Our goal is to create a very simple autonomous command to drive straight some specified distance. Seems like a very common use case, and we have looked through the CTR programmer guide and some code samples (found here https://github.com/CrossTheRoadElec/FRC-Examples AND https://github.com/ozrien/FRC-2016-Public) but none of these sources provide an example that simply does this. The encoder we are using is this one and we have it wired into the Talon via breakout board: http://www.andymark.com/E4T-OEM-Mini...-p/am-3132.htm We have a simple DriveTrain Subsystem -- for sake of this example it is pared down to just a single CANTalon that we are trying to control (source snip to follow). We also have a Command that calls the set() method of the Talon, passing in some desired number of units to move. First, we are wondering, what actually stops the motor - the encoder should work to stop it internally/automatically once the number of ticks have been counted - right? The Command should not have to do this when done. Expect all isFinished() is responsible for is telling the command scheduler that this command can be cleaned up/removed from executing. Further, we think the command's execute() method shouldn't have to do anything. Think all we need to do is update the set point of the Talon. Here is a bit of code showing what we are trying to do. What we see in practice is the position of the encoder updating, but the motor is not being stopped by the encoder control system. Rather we have to stop it in the command and we know this will not produce anything precise. Thanks in advance for any pointers/direction. Code:
public class DriveTrain extends Subsystem {
public CANTalon talon;
public DriveTrain() {
talon = new CANTalon(0);
talon.setControlMode(CANTalon.TalonControlMode.Position.value);
//This should be setting the set point to move encoder ticks
talon.set(0);
talon.setFeedbackDevice(FeedbackDevice.QuadEncoder);
talon.configEncoderCodesPerRev(1440);
talon.configNominalOutputVoltage(+0.0f, -0.0f);
talon.configPeakOutputVoltage(+6.0f, -6.0f);
talon.setAllowableClosedLoopErr(0);
talon.setPID(0.5, 0.001, 0.0);
talon.setPosition(0);
talon.enableControl();
public class DriveStraight extends Command {
private DriveTrain driveTrain;
private double numberOfUnits;
public DriveStraight(double numberOfUnits, DriveTrain driveTrain) {
this.numberOfUnits = numberOfUnits;
this.driveTrain = driveTrain;
protected void initialize() {
driveTrain.talon.reset();
driveTrain.talon.enable();
driveTrain.talon.setPosition(0);
driveTrain.talon.set(numberOfUnits);
protected void execute() {
// Should be nothing in here - right?
// Once the new setpoint is set in initialize the work is done.
protected boolean isFinished() {
if (numberOfUnits < 0) {
return (driveTrain.talon.getPosition() >= -numberOfUnits);
return (driveTrain.talon.getPosition() <= -numberOfUnits);
protected void end() {
// Shouldn't have to do this to get it to stop
driveTrain.talon.disableControl();
Re: CANTalon w/Encoder DriveStraight Command example
Thank you. Yep, the logic in the isFinished() looks odd because of the way the Talon was wired. Setting a positive setpoint was generating negative counts, so we compensated for that in the code.
We have got a simple command working and will post a cleaned up example of what we did tonight in case it helps others in the future. One thing that I don't entirely have my head wrapped around yet is the units used for some of the configuration. For example, with a 360 cycles/rev quad encoder, are we supposed to use Code:
talon.configEncoderCodesPerRev(360) Code:
talon.configEncoderCodesPerRev(360 * 4) Then there is also this Code:
driveTrain.talon.set(numberOfRevs) Code:
talon.setAllowableClosedLoopErr(allowableError) Again, thanks! |
As mentioned, here is the test code we used to learn about encoder-based control of a single talon. Now that we got this simplified code to work, we can move on to more realistic usages.
import com.ctre.CANTalon;
import com.ctre.CANTalon.FeedbackDevice;
import edu.wpi.first.wpilibj.command.Command;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
import org.usfirst.frc.team5976.robot.subsystems.DriveTrain;
* Drive the given distance straight (negative values go backwards).
private CANTalon talon;
private double numberOfRevs;
private int allowableError = 10;
private int stableCount;
private final int requiredNumberOfCounts = 10;
private double previousError;
public DriveStraight(double distanceInInches, DriveTrain driveTrain) {
talon = driveTrain.talon;
numberOfRevs = distanceInInches / (Math.PI * 6);
talon.set(0);
talon.configEncoderCodesPerRev(360);
talon.setProfile(0);
talon.setAllowableClosedLoopErr(allowableError);
// Get everything in a safe starting state.
driveTrain.reset();
talon.reset();
talon.enable();
System.out.println("Encoder start position: " + talon.getPosition());
System.out.println("Talon control mode: " + talon.getControlMode());
System.out.println("Number of Revolutions: " + numberOfRevs);
talon.set(numberOfRevs);
previousError = 100000; // something big to start with
stableCount = 0;
double currentError = driveTrain.talon.getError();
System.out.println("Encoder position: " + talon.getPosition()+
" |EP " + talon.getEncPosition() +
" |CErr " + currentError + " |PErr " + previousError + " |Count " + stableCount +
" |SetP " + talon.getSetpoint());
if (previousError == currentError) {
stableCount++;
if (stableCount >= requiredNumberOfCounts) return true;
else {
stableCount = 0;
previousError = currentError;
return false;
System.out.println("Encoder stop position: " + talon.getPosition()+ " | " + talon.getEncPosition());
// Called when another command which requires one or more of the same subsystems is scheduled to run
protected void interrupted() {
end();
P = 2 I = 0 D = 50 Ramp = 4 Talon control mode: Position Number of Revolutions: 1.0 Encoder position: 0.0 |EP 0 |CErr 1440.0 |PErr -9.0 |Count 2 |SetP 1.0 |T Time: 20 Encoder position: 0.0 |EP 0 |CErr 1440.0 |PErr 1440.0 |Count 0 |SetP 1.0 |T Time: 20 Encoder position: 0.001388888888888889 |EP 0 |CErr 1438.0 |PErr 1440.0 |Count 1 |SetP 1.0 |T Time: 20 Encoder position: 0.005555555555555556 |EP 0 |CErr 1424.0 |PErr 1438.0 |Count 0 |SetP 1.0 |T Time: 20 Encoder position: 0.022222222222222223 |EP 0 |CErr 1392.0 |PErr 1424.0 |Count 0 |SetP 1.0 |T Time: 22 Encoder position: 0.05 |EP 0 |CErr 1370.0 |PErr 1392.0 |Count 0 |SetP 1.0 |T Time: 18 Encoder position: 0.0875 |EP 126 |CErr 1314.0 |PErr 1370.0 |Count 0 |SetP 1.0 |T Time: 21 Encoder position: 0.13680555555555557 |EP 126 |CErr 1239.0 |PErr 1314.0 |Count 0 |SetP 1.0 |T Time: 19 Encoder position: 0.19444444444444445 |EP 126 |CErr 1151.0 |PErr 1239.0 |Count 0 |SetP 1.0 |T Time: 21 Encoder position: 0.25833333333333336 |EP 126 |CErr 1054.0 |PErr 1151.0 |Count 0 |SetP 1.0 |T Time: 24 Encoder position: 0.32569444444444445 |EP 126 |CErr 1003.0 |PErr 1054.0 |Count 0 |SetP 1.0 |T Time: 15 Encoder position: 0.3972222222222222 |EP 126 |CErr 898.0 |PErr 1003.0 |Count 0 |SetP 1.0 |T Time: 20 Encoder position: 0.46944444444444444 |EP 645 |CErr 789.0 |PErr 898.0 |Count 0 |SetP 1.0 |T Time: 21 |
I would personally do in isFinished:
