Go to Post Gracious professionalism dictates that if you come to play, I must help you. - Al Skierkiewicz [more]
Unread 22-01-2017, 14:39
Southpaw's Avatar
Southpaw Southpaw is offline
AKA: Spencer Robinson
FRC #3184 (Blaze Robotics)
Southpaw is on a distinguished road
Re: White Lithium vs. "Strawberry Jam" grease
[quote=Ether;1634784]The cost of the used grease is not the issue. It's the time and effort required to thoroughly remove the used grease if it is chemically incompatible with the replacement grease.
Building drive trains has left me cleaning grease off of my hands multiple times. Cleaning grease out of a gearbox will not take any significant time. I had stated that it depends on your certainty level. You could go with the idea that "Red n Tacky is extremely similar therefore AM grease is most likely lithium based and compatible", or you could go on the safe end and clear out the gearbox and apply the new grease.
