Go to Post Life is not about avoiding risk, but managing it. - dtengineering [more]
Unread 22-01-2017, 01:31
KohKohPuffs KohKohPuffs is offline
The one with the punny last name
AKA: Daniel Koh
FRC #0299 (Valkyrie Robotics)
KohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura aboutKohKohPuffs has a spectacular aura about
White Lithium vs. "Strawberry Jam" grease
Our team is modifying the Andymark Toughboxes to have different gear ratios. As such, we have purchased some gears from VexPro, but unfortunately we don't have more of the "strawberry jam" grease that came with the toughboxes in the kitbot chassis.
I intend on running to the local hardware store tomorrow to acquire white lithium grease, but we're wondering if we need to clean out the toughboxes of the "strawberry jam". Like, if there's some of it left, will it react with the white lithium and cause an explosion or something of the sort (exaggerated, but you get the idea )?
Also, what's the official name for that grease? We all call it "strawberry jam" because it looks like it... except that it's not.
-KohKoh
115 MVRT, Driver (2013-2015)
649 M-SET, CAD (2015-2016)
299 Valkyrie Robotics, Mechanical Director (2016 - present)
Unread 22-01-2017, 01:35
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: White Lithium vs. "Strawberry Jam" grease
I am fairly sure that a) the "strawberry jam" is red lithium grease and b) you can mix them without any ill effects.
"The breakfast of champions!"
Unread 22-01-2017, 01:43
Sometimes, you gotta go to the source...
http://www.andymark.com/red-tacky-gr...-p/am-2768.htm
It's described as raspberry jam in appearance by AM.
(I suggest buying a LOT of packets, or something else that's heavier and would pack well with packets--don't want shipping to be more than your order!)
Unread 22-01-2017, 01:52
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Why buy packets when you can buy in bulk?
http://lucasoil.com/products/grease/red-n-tacky-grease
Amazon
Home Depot
Auto Zone
IMO, the red tacky grease holds up a lot better than white lithium grease. I've gone entire seasons without re-greasing after assembling gearboxes with generous amounts of the red grease.
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 22-01-2017, 07:16
ShIfTiNgBoT's Avatar
ShIfTiNgBoT ShIfTiNgBoT is offline
AKA: David
FRC #0649
ShIfTiNgBoT is on a distinguished road
Do not mix them (probably). There are two kinds of white lithium greases, a spray-on form, and a paste form. The spray on kind will not function as intended, as it evaporates and leaves a film behind which is the lubricant. You may have better luck with the paste form of white lithium (comes in tubes, not cans), although my guess for that is only speculation.
Either way, it's almost always good form to remove previous lubrication when switching to a different kind.
Unread 22-01-2017, 09:14
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
You can go to any auto parts store and ask them for Red 'n Tacky grease if you'd rather stay with the same stuff.
Unread 22-01-2017, 10:39
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
[Boston accent] Ah jus' throw some butta on it and quitcha whinin' [/Boston accent]
Unread 22-01-2017, 10:52
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
a small tub of red grease from an auto parts store (or Walmart) is not very expensive, and will last a long time! And you can pack the wheel bearings in your trailer with it, too.
Unread 22-01-2017, 11:22
Michael Hill's Avatar
Only ONE MAN would DARE give me the RASPBERRIES...ANDY BAKER...
Unread 22-01-2017, 13:05
Southpaw's Avatar
Southpaw Southpaw is offline
AKA: Spencer Robinson
FRC #3184 (Blaze Robotics)
Southpaw is on a distinguished road
There should be no problem mixing them, assuming the AM grease is indeed Lithium. This chart shows lithium grease types are compatible with each other, and should not have any problem being mixed.
http://www.machinerylubrication.com/...mixing-greases
This being said, if you are still uncertain, used grease is used grease and cheap and you could replace it.
Unread 22-01-2017, 13:25
The cost of the used grease is not the issue. It's the time and effort required to thoroughly remove the used grease if it is chemically incompatible with the replacement grease.
Unread 22-01-2017, 14:39
Southpaw's Avatar
[quote=Ether;1634784]The cost of the used grease is not the issue. It's the time and effort required to thoroughly remove the used grease if it is chemically incompatible with the replacement grease.
Building drive trains has left me cleaning grease off of my hands multiple times. Cleaning grease out of a gearbox will not take any significant time. I had stated that it depends on your certainty level. You could go with the idea that "Red n Tacky is extremely similar therefore AM grease is most likely lithium based and compatible", or you could go on the safe end and clear out the gearbox and apply the new grease.
Unread 23-01-2017, 17:16
DonRotolo's Avatar
Back to humble
FRC #0832
Hm, on this end it came out as a heavy Bronx accent.
Best you learn about Nitrile Gloves. Chemicals on Skin is easily avoided, and should be.
Clean the old grease off with isopropyl alcohol (with good ventilation): The 91% stuff is an excellent degreaser. That and a toothbrush will make short work of it.
I can also speculate that mixing is harmless, but what if I'm wrong?
Unread 23-01-2017, 18:05
Some 40-plus years ago when I was just a pup working in the gas turbine engine fuel control lab, my mentor constantly had his hands immersed in Trike.
I found out many years later it did not end well.
Unread 23-01-2017, 18:44
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
WD40 also works as a very good degreaser. I'll second wearing gloves instead, but if that's not an option, most workshops have WD40 lying around.
423 has a tube of white lithium grease that we used to grease all our gearboxes. Some of those gearboxes were AndyMark gearboxes with Strawberry Jam grease still in them (some also had a green grease I can't identify). As far as I know, we never saw any reactions or interactions between the two (or three) greases.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
