Go to Post Where's the "drill enough weight holes so we're barely under 120lbs" option? ;-) - AlecMataloni [more]
Unread 22-01-2017, 14:33
Glitch159's Avatar
Glitch159 Glitch159 is offline
FRC #0839 (Rosie Robotics)
Glitch159 is an unknown quantity at this point
Motion Profiling won't work
Hello! So, we are testing motion profiling on a robot, and we are able to feed the points to it, but it doesn't seem to want to actually utilize these points for anything (as in, it is getting the points, but not moving at all). We've made sure that the robot is physically fully functional, so it isn't a hardware problem. Any help would be appreciated. Thanks
Unread 22-01-2017, 15:20
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Re: Motion Profiling won't work
Something like this is really hard to diagnose without some code. Could you share it?
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 22-01-2017, 17:02
Have you carefully followed the detailed steps provided in Section 6 of this document?
Unread 23-01-2017, 19:24
Glitch159's Avatar
First of all, that entire document has been read in it's entirety, and we made sure that we added in everything that was specified that we would need. Second of all, here is the code:
package org.usfirst.frc.team839.robot.commands;
import org.usfirst.frc.team839.robot.instrumentation;
import edu.wpi.first.wpilibj.CANTalon;
import edu.wpi.first.wpilibj.CANTalon.FeedbackDevice;
import edu.wpi.first.wpilibj.CANTalon.TalonControlMode;
import edu.wpi.first.wpilibj.command.Command;
public class GoodMotionProfileCommand extends Command
	CANTalon _talon = new CANTalon(5);
	CANTalon _talonSlave = new CANTalon(4);
	//MotionProfileExample _example = new MotionProfileExample(_talon);
	private CANTalon.MotionProfileStatus _status = new CANTalon.MotionProfileStatus();
	boolean isFinished = false;
	double[][] profile;
	public GoodMotionProfileCommand(double[][] points)
		System.out.println("GoodMotionProfileCommand constructor");
		profile = points;
	@Override
	protected void initialize()
		System.out.println("GoodMotionProfileCommand initialize");
		_talon.clearMotionProfileTrajectories();
		_talon.setFeedbackDevice(CANTalon.FeedbackDevice.QuadEncoder);
		_talon.reverseSensor(false);
		_talon.changeControlMode(TalonControlMode.MotionProfile);
//		_talonSlave.changeControlMode(TalonControlMode.Follower);
//		_talonSlave.set(5);
		_talon.set(CANTalon.SetValueMotionProfile.Disable.value);
		_talon.changeMotionControlFramePeriod(10);
		//feed Trajectory Points
		fill(profile,profile.length);
		_talon.set(CANTalon.SetValueMotionProfile.Enable.value);
//		_talon.processMotionProfileBuffer();
	private void fill(double[][] profile, int totalCnt) {
		System.out.println("GoodMotionProfileCommand fill");
		/* create an empty point */
		CANTalon.TrajectoryPoint point = new CANTalon.TrajectoryPoint();
		for (int i = 0; i < totalCnt; ++i) {
			/* for each point, fill our structure and pass it to API */
			point.position = profile[i][0];
			point.velocity = profile[i][1];
			point.timeDurMs = (int) profile[i][2];
			point.profileSlotSelect = 0; /* which set of gains would you like to use? */
			point.velocityOnly = true; /* set true to not do any position
										 * servo, just velocity feedforward
			point.zeroPos = false;
			if (i == 0)
				point.zeroPos = true; /* set this to true on the first point */
			point.isLastPoint = false;
			if ((i + 1) == totalCnt)
				point.isLastPoint = true; /* set this to true on the last point  */
			_talon.pushMotionProfileTrajectory(point);
	@Override
	protected void execute()
		_talon.getMotionProfileStatus(_status);
		if(_status.hasUnderrun)
			System.out.println("GoodMotionProfileCommand _status.hasUnderrun");
			//load points
			_talon.clearMotionProfileHasUnderrun();;
		if (_status.activePointValid && _status.activePoint.isLastPoint)
			System.out.println("GoodMotionProfileCommand  _status.activePoint.isLastPoint");
			_talon.set(CANTalon.SetValueMotionProfile.Hold.value);
			isFinished = true;
		else
			instrumentation.process(_status);
	@Override
	protected boolean isFinished()
		return isFinished;
	@Override
	protected void end()
		System.out.println("GoodMotionProfileCommand end");
		_talon.changeControlMode(TalonControlMode.Voltage);
	@Override
	protected void interrupted()
Unread 23-01-2017, 23:03
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Did you set the gains?
Screenshot the selftest in the web based config.
What firmware version?
Unread 25-01-2017, 19:07
Glitch159's Avatar
Firmware is up to date, and we added the Feed-forward gains as well as P, I, and D gains. We finally have the motors turning now However, there is a new problem: we've had to ramp up the acceleration value to something that sounds unreasonable.
