Go to Post At first, "water game" was funny. Then it went to silly. Now it's just dumb. Not to mention unrealistic for FIRST. - EricH [more]
Unread 21-01-2017, 18:06
AccioTardis221 AccioTardis221 is offline
AKA: Allison
FRC #5847 (Ironclad)
Rookie Year: 2015
AccioTardis221 is an unknown quantity at this point
Read from an encoder
We've been attempting to use an encoder, but unable to read data from it. We have an SRX Mag Encoder from CTRE. It's plugged into the data port on a talon SRX. We have attempted to read from it using the Get Status VI in the Talon library, but it has only given an output of 0. Everything appears to be connected correctly and the program runs, it just doesn't provide any data. How do we read from these encoders?
Unread 21-01-2017, 23:02
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Read from an encoder
Are you telling the Talon the correct type of feedback device?
Section 7.1 of the manual
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 22-01-2017, 16:29
Jonathan L. Jonathan L. is offline
Programmer alumnus, mentor, and CSA
FRC #1094 (Channel Cats)
Jonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the rough
Try simplifying. Instead of plugging the encoder into the Talon SRX, plug it into the DIO ports on the roboRIO and use the LabVIEW example program for Encoders found by going to Help -> Find Examples and looking in the "Digital" folder. The wiring diagram for connecting the encoder to the DIO ports is on the front panel of the example program.
If that works, then you know the encoder is working and you can worry about the Talon SRX.
