Go to Post Sometimes dumb ideas just work really well :P - Garrett.d.w [more]
View Poll Results: What is your drivetrain's top speed?
<10 7 2.94%
11-13 (kitbot is here) 48 20.17%
14-16 96 40.34%
17-20 72 30.25%
>20 15 6.30%
Voters: 238. You may not vote on this poll
Unread 22-01-2017, 12:51
jdaming jdaming is offline
jdaming is on a distinguished road
What is your drivetrains top speed in FT/S (FPS)? If you are doing a shifting drivetrain please comment with your low speed too! I would love to hear any other comments about what you think is "best" and why!
Mentor since 2007 in:
Austin, TX
St. Louis, MO
New Orleans, LA
Kansas City, MO
My current local team is: 2167
Unread 22-01-2017, 13:01
Billfred's Avatar
Billfred Billfred is offline
Re: What is your drivetrain's top speed?
Your poll has an issue; we clock the stock AM14U3 at 10.0 feet per second in the user guide (PDF link). (That uses 75% of free speed for calculations, to account for losses to friction.) If you meant it to be 10-13 (since the previous option is "less than 10"), you'd be correct.
As for Iron Kings, we'll be around 15 theoretical or about 13 in practice. 5.95:1 gearing, 4" HiGrip wheels.
(Full disclosure of the painfully obvious: I work at AndyMark.)
Unread 22-01-2017, 13:06
Yes, that was meant to be 10-13. I did see that the kitbot was listed at but also thought (or hope) that most kitbot teams will elect to use two CIM motors rather than just one that the 10 is derived from.
Austin, TX
St. Louis, MO
New Orleans, LA
Kansas City, MO
Unread 22-01-2017, 13:16
Billfred's Avatar
If you use two CIMs or one, your top speed will not increase--simply how fast you get to it (and how much current a motor will draw). To go faster, you would have to change the gearing or start integrating motors with a higher free speed (like a Mini CIM, whose free speed is about 500 RPM faster).
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
The number of CIMs does not affect the top speed of the kitbot, just the acceleration and some other stuff.
Unread 22-01-2017, 13:21
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Using multiple motors won't change the top speed significantly, though they will decrease the time it takes to get to top speed.
3946 is geared for 12.7 ft/s per AM's calculations - 2015 gearing, 2016-17 wheels. We're using 4 drive CIMs and keeping the weight down by only using four wheels and two belts on a "half-long" chassis to keep the current draw reasonable.
OBTW, thanks to the folks at AM for putting those churro holes 4-1/4" either side of the drive bearing! So far, the only drilling we've done to the chassis were to accommodate rivets and rivnuts rather tan 10-32 and nylocks.
Unread 22-01-2017, 14:06
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
I'm having a really hard time with the idea that 17+ fps is ever a good idea for most teams. I'm also having a hard time with the polling results that seem to show most respondents disagree. YIKES
http://www.angelbotics.com
Remember why you're doing this.
Unread 22-01-2017, 14:15
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Our robot will be zippy. Cruising ratio will be less than 5.7:1. Not saying exactly how much less.
More critical questions might be, how many seconds will your driver need to move the robot from a retrieval zone to an elevator, or the other way 'round? How many seconds will a defender be able to delay that?
Richard Wallace
since 2003
Unread 22-01-2017, 14:31
mrnoble's Avatar
teacher/coach
EEP. Okay.
My question to you, oh CD Community, is this: do you have any students who have driven a robot that travels 17 fps or faster? 14-15 fps is on the edge of control for most drive teams, and the last two years had games in which something between 7-11 fps was usually ideal, so unless your drivers are seniors with experience in Aerial Assault as freshman, this will be a significant challenge.
My question to myself is: which do I think is likely; that those responding to this poll don't realize that their Toughbox Mini only goes at 10fps, or, that my team will be struck by a careening, out-of-control alliance parter while lining up to receive a gear or a load of fuel? I think I will prepare for the worst, and add extra thickness to our gussets. 2014 is still a raw memory.
Unread 22-01-2017, 15:12
BrennanB's Avatar
BrennanB BrennanB is offline
TBC is good at getting almost first
AKA: Brennan Bibic
FRC #4476 (W.A.F.F.L.E.S.)
BrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond repute
Originally Posted by mrnoble View Post
EEP. Okay.
The answer is to your question is: It doesn't matter.
If you have alliance partners in quals that bump into you while loading for gears, so will other people. Make your gear pickup more reliable so it doesn't matter. Don't pick teams that can't drive, and you being careful of overgearing your robot will be more desirable as you will be able to control your robot.
Rather than trying to change other people's designs over a message board, count yourself lucky that you have thought of this potential issue and come up with one of the several solutions to the issue. You will be a more attractive pick for it.
Other teams can do what they want, maybe they have the ability to make the drivetrain work better than a lower geared one. I don't know if they can, you don't know if they can, I bet some of the teams attempting don't even know if they can. The concerns are valid, but it's not for us to judge them this early in the season.
Brennan Bibic - @b_bibic - Eh-Nalysis
10 years of inspiration compilation - W.A.F.F.L.E.S. #4476 YouTube Channel - 64 events and counting!
FRC 2013-2017 (W.A.F.F.L.E.S. Community Robotics #4476) - FLL 2006-2017 (W.A.F.F.L.E.S. #105) - VRC 2010-2013, 2015-2016 (W.A.F.F.L.E.S. #4476)
FRC 2009-2012 (K-Botics #2809)
Fantasy First 2014-2017 (The Breakfast Company) #TBCWin
2014 Dean's List Finalist
"Work until your idols become your rivals."
Unread 22-01-2017, 15:23
mrnoble's Avatar
teacher/coach
Originally Posted by BrennanB View Post
It's not for us to judge them this early in the season.
Who's judging? This early in the season, when teams have some time left to work on their designs, CD is about the best place there is to get advice from people with experience. Teams have their own ideas and they will do what they want, but now is the time to give and receive advice.
Unread 22-01-2017, 15:28
BrennanB's Avatar
AKA: Brennan Bibic
Absolutely! Advice is a good thing. Just no need to freak out about the poll results of only around 100 respondents say that the majority are gearing their robot fast on a flat field.
Teams should heed the advice in this thread, though I would hope most teams have their drive train worked out by now.
Unread 22-01-2017, 16:58
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
We're running the same setup with wheels from 2015's kit since we used 6" wheels that year.
I understand the theoretical max speed won't increase with additional CIMs since they all have the same free speed, but won't the effective speed you can reach change because of the additional torque available at the same point on the motor torque/speed curve? If the kitbot is rated at 75% of free speed due to friction losses on one CIM per side, then I would think the additional CIM per side would add enough extra power to run at a higher percentage of free speed before friction becomes the limiting factor again. Is there a significant amount of friction added from the extra gear for the second CIM?
Unread 22-01-2017, 17:15
Chris is me's Avatar
AKA: Pinecone
228's going 4 CIM, 14 / 6 ballshifters. For packaging more than anything else - the 2 CIM model is a really compact gearbox, but the 3 CIM is huge.
Unread 22-01-2017, 17:21
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
14+ fps is drivable if your drivers get a LOT of practice. I would never gear a bot that fast without a practice bot.
Our fastest bot ever was 17.3 free speed but our driver had more than 50 hours of drive time before our first event.
