Go to Post that is one of the funniest non-photoshoped pictures of my father i have seen... - Lil' Lavery [more]
Unread 22-01-2017, 19:45
Robochris Robochris is offline
FRC #6722
Robochris is an unknown quantity at this point
CIM coders help!
Im having trouble programming the CIMcoders. Please correct me if you see something wrong im new at this.
So I have the Encoder plugged into the DIO on the roboRIO. From left to right on the encoder when placed on a motor, I have the 1st pin in DIO 0: 5V, 2nd pin in DIO 1: signal, 3rd pin in DIO 0: GRN, 4th pin in DIO 0: signal.
On the code side I am using C++. The Encoder stuff is inside a command and none of it is in the Robot.cpp or the main one. The "DriveCommand" is an Autonmous btw, not sure if that helps. When ever i run it in the FRC Drive Station, I get these errors. Need anymore information fill free to let me know. Thanks
ERROR -1029 HAL: Resource already allocated, Minimum Value: 0, Maximum Value: 20, Requested Value: 0 PWM [PWM.cpp:43]
ERROR -1029 HAL: Resource already allocated, Minimum Value: 0, Maximum Value: 20, Requested Value: 1 PWM [PWM.cpp:43]
ERROR -1029 HAL: Resource already allocated, Minimum Value: 0, Maximum Value: 31, Requested Value: 0 DigitalInput [DigitalInput.cpp:43]
ERROR -1029 HAL: Resource already allocated, Minimum Value: 0, Maximum Value: 31, Requested Value: 1 DigitalInput [DigitalInput.cpp:43]
ERROR -1098 HAL: A handle parameter was passed incorrectly InitEncoder [Encoder.cpp:43]
Them sick codez
#include "DriveCommand.h"
#include "WPILib.h"
#include "CANTalon.h"
using namespace frc;
bool done = false;
Victor *victor;
CANTalon *talon;
Victor *victor2;
CANTalon *talon2;
Encoder *CIM;
DriveCommand::DriveCommand() {
	victor = new Victor(0);
	victor2 = new Victor(1);
	talon = new CANTalon(1);
	talon2 = new CANTalon(2);
	CIM = new Encoder(0, 1, false, Encoder::EncodingType::k4X);
void DriveCommand::Initialize() {
void DriveCommand::Execute() {
	if (!done) {
		victor->Set(CIM->Get() > 5 ? 0 : 1);
		done=true;
execute()
bool DriveCommand::IsFinished() {
	return done;
void DriveCommand::End() {
	victor->Set(0);
	talon->Set(0);
void DriveCommand::Interrupted() {
Thanks for your help!
Unread 22-01-2017, 20:21
Adnewhouse's Avatar
Adnewhouse Adnewhouse is offline
FRC #0639
Adnewhouse is an unknown quantity at this point
Re: CIM coders help!
I think you might want to add parentheses to make it look like this:
victor->Set((CIM->Get() > 5) ? 0 : 1);
Also, if you want to use encoders and victors on the same ports during teleop, you should create those objects in a single file called RobotMap.cpp and then pass them along to each subsystem, not inside a command. Things can get really messy when you start creating objects inside commands. Have a look at our 2016 kitbot code for how we usually do it (sorry it's really messy, things haven't been cleaned up). Also check out wpilib for more details and best practices for command based code: http://wpilib.screenstepslive.com/s/...ed-programming
Unread 22-01-2017, 20:35
FRC #6722
Thank you sir i will definitely try that. Thanks for showing an example.
Unread 22-01-2017, 21:00
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
It looks like you are creating multiple instances of the command which is trying to allocate the same port multiple times. I think you want this to be a Subsystem instead of a command. Have you looked into using RobotBuilder to setup the framework of your code?
https://wpilib.screenstepslive.com/s/4485/m/26402
Unread 22-01-2017, 21:04
AKA: Brad
#0190 ( Gompei and the Herd)
In your example you are creating CANTalon objects, so the number in the constructor is actually the CAN ID and not a roboRIO port number. So that in itself should not be a conflict.
I'm wondering if the command is being created more than once, which would cause duplicate allocations which are indicated by your output:
Ideally you would want to create the sensors and speed controllers in a subsystem rather than a command and refer to methods on the subsystem to actually operate the drive base. That way, creating multiple instance of commands won't double-allocate the sensors.
Brad Miller
Robotics Resource Center
Unread 28-01-2017, 10:25
brainbounce brainbounce is offline
AKA: Bob
FRC #3225 (Wolverine Robotics)
Rookie Year: 2016
brainbounce is an unknown quantity at this point
I don't think you should try to debug your program until you have the wiring correct. The CIMCoder uses 2 DIO slots on the RoboRio, and needs external pull-up resistors.
Download the spec sheet from AndyMark to verify, but:
Orange Pin1 goes to +5V
Blue Pin2 goes to Signal0
Black Pin3 goes to GND
Yellow Pin4 goes to Signal1
(2) 10K pull-up resistors between +5V and each of the signal wires.
Unread 28-01-2017, 19:14
garyk garyk is offline
Programming Mentor: 668, 972, 2643
FRC #0668 (Apes of Wrath)
garyk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the roughgaryk is a jewel in the rough
The RoboRIO DIO pins (when configured as Digital Inputs) are already pulled up, as were the same pins on the cRIO's Digital Sidecar and the ancient IFI Robot Controller. (Translation: the resistors aren't needed. Or are the CIMCoder's electrical signals in need of a stronger pullup?) Ref: NI roboRIO Users manual, Figure 16:
Silicon Valley Regional 2005, 2006 972
Silicon Valley Regional 2007 668 Xerox Creativity Award
Championship Event 2007 668
Portland Regional 2008 668
Silicon Valley Regional 2008 668, 972
Beta Test Team 2008 668 (with 100 & 254)
Silicon Valley Regional 2009 668 Regional Chairman's Award; 2643
Sacramento Regional 2009 668 Winning Alliance (thanks, 1717 & 2473!), 2010 Winning Alliance 3256
CalGames 2006, 2007, 2008, 2009, 2010, 2011 Field Tech
NorCal FTC Regional 2008, 2009 Inspector
Championship Event 2009
San Diego, Silicon Valley Regionals; Champ. Event 2010 668, 2643, 3256
Silicon Valley, Madera Regional 2012 2643
WRRF Programming Instructor 2006-2016
Regional Woodie Flowers Award 2014 2643 Utah Regional
Unread 30-01-2017, 23:24
dravis dravis is offline
AKA: Ben Randolph
FRC #0663
dravis is an unknown quantity at this point
I am also wondering if you need to use pull up resistor for the CIMCoder. I have used them without and didn't seem to have any issue. But based on the specs for CIMCoder it indicates we would need ~3-4k resistor for 5V supply.
