Go to Post We're 3 pounds over. Drill until the hole saw is too hot to touch, then go find something else to cut off while you wait for it to cool down. - Richard Wallace [more]
Unread 22-01-2017, 23:56
feverittm's Avatar
feverittm feverittm is offline
FRC #0997 (Spartans)
feverittm will become famous soon enoughfeverittm will become famous soon enough
Getting a CSV filr from Java Smartdashboard/Console
We are working to tune our PIDF controller on out shooter prototype and would like to plot/analyze the system response in Excel. However, we don't have any data logging code in our build (and would have to design it anyway). We would therefore like to figure out a way to grab the data from either the Smartdashboard or from the Console output.
Has anyone done this before and have a solution?
Thanks
Floyd Moore
Mentor Electrical and Pneumatics
Team 997 - Spartan Robotics
Corvallis High School, Corvallis Oregon
Unread 23-01-2017, 09:20
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Getting a CSV filr from Java Smartdashboard/Console
With the default dashboards, no. If you log in a comma-separated format, you might be able to save the data as a CSV file. But I'd recommend simply making your robot code save a CSV file on the rio which you can then copy out.
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 23-01-2017, 09:47
gbear605's Avatar
gbear605 gbear605 is offline
Scarebear
FRC #1768 (Nashoba Robotics)
gbear605 is an unknown quantity at this point
If you use SmartChart (an SFX Smart Dashboard plugin that my team made), it can export data to a CSV file. It also has a bunch of other neat features, like graphing based on time or being able to reset without making a new graph. More features are on the way, like zooming. The file to download is at https://github.com/Nashoba-Robotics/SmartChart/releases
You could also write a way to save the CSV file on the roboRIO and then use FTP to get the file out. It shouldn't be too complex to write, since CSV is a super simple protocol.
Unread 24-01-2017, 15:35
gerthworm's Avatar
gerthworm gerthworm is offline
Making the 1's and 0's
FRC #1736 (Robot Casserole)
Rookie Year: 2015
gerthworm has a spectacular aura aboutgerthworm has a spectacular aura about
And, if you decide to go the route of logging on the RIO, here's an example of how we did it last year:
https://github.com/RobotCasserole173...CsvLogger.java
It's set up to save to an external flash drive at the moment, but you can adjust the "output_dir" variable to wherever you like.
