Go to Post We should have a 'Steps Taken For FIRST' contest. Everyone wear a pedometer and keep a log of how many miles you walked at the St. Louis Championship. That could be a lot of fun. Do they make pedometers for robot carts? - JaneYoung [more]
Unread 22-01-2017, 22:49
ollien ollien is offline
FRC #5202
ollien is just really niceollien is just really niceollien is just really niceollien is just really nice
Wheel replacement.
I'm doing some research into swapping out our hi-grip wheels with other wheels in a KoP chassis. After some research, I have a few lingering questions.
1) Is it really worth it to switch away from the higrip wheels? Is there a large amount of benefit to going to some other wheel, especially if you're being defended against? There also doesn't seem to be much benefit to the other durometers of the hipgrip wheel, considering the low difference in CoF and lower durabilities.
2) I've read about the performance wheels throwing tread. Is the same true for plaction wheels? I would hate to see us lose a match because a wheel threw tread.
3) If we went with plaction + blue nitrile, how often should we expect to have to replace the tread?
Unread 22-01-2017, 22:52
Chris is me's Avatar
AKA: Pinecone
Re: Wheel replacement.
The CoF difference, even a factor of .1 or so, is pretty significant. A 10% increase in traction could win you the pushing match. It really depends on how much you can afford to spend and how willing you are to change out wheels, which isn't very easy to do on a kitbot.
Throwing tread is a possibility with any traction wheel, but properly installed tread that is riveted into place should not throw. Teams have used treaded wheels for years successfully, it's just another thing to watch out for maintenance wise.
Blue nitrile is the most durable of the different kinds of roughtop. You should expect to change them possibly once or twice a season depending on how big your wheels are, how much defense you play, etc. Other kinds of roughtop might be a once or twice an event sort of thing.
Unread 22-01-2017, 23:04
FRC #5202
The blue higrips only have a .01 difference from the white ones. 1%.
That being said, the amount of time required to swap out wheels is worth thinking about. Thank you!
Unread 22-01-2017, 23:09
AKA: Pinecone
Just based on anecdotal evidence alone, I would doubt that number. The wheels handle and behave extremely differently. I know it's what it says on their website, but they really feel and behave way differently.
Unread 22-01-2017, 23:20
Billfred's Avatar
Billfred Billfred is offline
I've spoken with the engineers about this one at length (short conversations are in short supply in that office). There have been some test chassis driving around on black HiGrips, and they do have noticeably better grip that somehow isn't getting reflected in our CoF calculations--part of that comes down to the tread profile of the HiGrips, since interlocking with field carpet creates more usable grip than the same material not interlocking. I was hoping we'd have this improved by Kickoff, but other priorities had the engineers busy.
For what it's worth, Iron Kings will be running black 4" HiGrips this year and have expectations of swapping them out about once a competition day depending on our driving. The blue HiGrips are more manipulator-oriented; I don't think anyone has been bold enough to use them on an FRC-scale drive system yet because the compound is so darn soft. If you've ever rubbed a thumb on black and blue Stealth Wheels or Compliant Wheels that use the same material, you know the difference. (White HiGrips and gray Stealth Wheels are also the same durometer, just colored differently.)
Botty McBotface (the Team Indiana Ri3D build) has blue HiGrips on there, and I'm hoping to get it going against our own driver before bag day. Should be a hoot!!
(Full disclosure of the painfully obvious: I work at AndyMark.)
Unread 23-01-2017, 00:20
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
1)Is it really worth it to switch away from the higrip wheels?
I've no idea about the actual benefits you'll see on the Field from switching away from the KOP wheels. But the perceived benefit of having better wheels may be worth its weight in gold. If having different wheels puts you just above some of the other competition in the eyes of picking teams, they'll be worth it.
Unread 23-01-2017, 08:54
Joseph Smith's Avatar
Joseph Smith Joseph Smith is offline
Persistence alone is omnipotent.
FRC #3539 (Byting Bulldogs)
Joseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant future
My team has used wheels with rivet-on treads on three of our robots- 2011 (plaction wheels), 2013 (custom 6" aluminum wheels) and 2014 (andymark 4" performance wheels). We used roughtop tread all three years. We would typically replace our tread once per competition, usually before playoffs. We never threw a single tread. The important part is to keep the tread pulled tight as you rivet it down.
Design/fab team 2011-2013
Design/fab mentor 2014--
There are three types of people in the world:
1. Those who make things happen
2. Those who watch things happen
3. Those who wonder what happened.
Unread 23-01-2017, 09:47
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
The pattern on the hi-grip wheels can, and has, peeled up the fields' gaffer's tape, causing drive-train problems. See: https://www.chiefdelphi.com/forums/s...=127368&page=6
https://www.chiefdelphi.com/forums/s...=127368&page=5
etc.
Specifically
(From Falcon Robotics)
I witnessed this occurrence more than once last year. I, personally, would use a different wheel with a smooth tread based on these observed issues and my expectation that defense will be quite heavy this year.
Unread 23-01-2017, 10:28
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Well, I mistakenly ordered the blue higrips for our bot(wanted black) we will see how they perform on our practice bot. If wear is a big issue we my be buying more wheels.:>)
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
