Go to Post As a wise man from PA once said to me "Changing the culture is hard work." - RoboMom [more]
Unread 23-01-2017, 11:32
Maju Maju is offline
FRC #1382
Maju is an unknown quantity at this point
Circuit break
Can we use more than one circuit break in the robot?
Unread 23-01-2017, 11:37
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Circuit break
Originally Posted by R44
..the one (1) main 120-amp (120A) circuit breaker (Cooper Bussman P/N: CB185-120)..
Exactly one main breaker. Multiple individual breakers will certainly be required in the power distribution panel.
Unread 23-01-2017, 11:38
Adnewhouse's Avatar
Adnewhouse Adnewhouse is offline
FRC #0639
Adnewhouse is an unknown quantity at this point
Re: Circuit break
Answer in the manual:
R44. The one (1) ROBOT battery, a single pair of Anderson Power Products (or APP) 2-pole SB type connectors, the one (1) main 120-amp (120A) circuit breaker (Cooper Bussman P/N: CB185-120), and the one (1) CTR Electronics Power Distribution Panel (PDP, P/N: am-2856, 217-4244,14-806880) shall be connected with 6 AWG (7 SWG or 16 mm2) wire or larger, with no additional devices or modifications, as shown in Figure 8-8.
If you're talking about the main breaker, only one is allowed.
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Re: Circuit break
Do you mean the 120A main breaker? Then no, you can only have 1.
Do you mean the snap-action breakers on the Power Distribution Panel? Then yes, it is fully expected to have several there.
Edit: Super ninja'd
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
