I'd flip my normals for you.
Unread 23-01-2017, 14:11
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Gear Sliding down Ramp
Originally Posted by Robosparks2926 View Post
Is there reflective tape on the peg/ platform for the gear placement?
Yes, section 3.13 of the rules, details in figure 3-36.
Unread 23-01-2017, 14:16
rlance rlance is offline
FRC #5550
rlance is a splendid one to beholdrlance is a splendid one to beholdrlance is a splendid one to beholdrlance is a splendid one to beholdrlance is a splendid one to beholdrlance is a splendid one to beholdrlance is a splendid one to behold
It is in the rules under Arena 3.13
Unread 23-01-2017, 14:18
s-neff's Avatar
s-neff s-neff is offline
AKA: Sam
FRC #0841 (Biomechs)
s-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud ofs-neff has much to be proud of
Sorry, but those actually are completely different plastics for the application.
The coefficients "look similar", but going from 0.28 to 0.38 [as quoted earlier in thread] is a 30% increase in friction!
Textured FRP or textured ABS are both much better choices than smooth polycarb, if you can't get HDPE in either smooth or "orange peel". Consider bringing the gear to the store to test your substitute-of-choice before buying?
(Our smooth HDPE works great, I haven't tested our textured ABS)
Fun:
Mentor - Team 841 (2015 - ? )
Mentor - Team 4 (2013 - 2014)
Student - Team 192 (2009 - 2010)
Work:
SunPower Systems, Product Engineering - Utility Power Plants (2015 - ? )
BSci, Mechanical Engineering, UCLA (2010-2015)
Unread 23-01-2017, 14:51
juju_beans's Avatar
juju_beans juju_beans is online now
FRC #3647 (Millennium Falcons)
Rookie Year: 2016
juju_beans is an unknown quantity at this point
We used some fiberglass and it worked pretty well but you have to be careful when cutting it.
This is safe... right?
Unread 23-01-2017, 15:39
Ronny Mohtar Ronny Mohtar is offline
FRC #5805
Ronny Mohtar is an unknown quantity at this point
Code Orange cut off a piece of FRP that they used so we (SMbly Required) didn't have to order it. We both used it for the ramp and it works very well.
Unread 23-01-2017, 15:43
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Practice with something as close to the real thing as possible. If your robot is relying on the gear slowly plopping out of the chute because you designed around a wooden chute you'll be really upset at comp... unless you do floor pickup. Then whatever
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 24-01-2017, 15:25
Tanya & André Tanya & André is offline
FRC #4955
Tanya & André is an unknown quantity at this point
Upon searching some reference material, we found that Formica has a similar coefficient of friction to HDPE. If someone on the team has recently renovated an old kitchen, perhaps you can find a piece large enough. We find it works well for us - no problem with sliding.
Unread 24-01-2017, 16:17
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
In a similar-to-but-not-exactly-related vein:
Adding a bit of duct tape to the bottom of a gear and then sliding it across the school's tiled (linoleum?) floor was approximately the same friction as a plain gear sliding across carpet. Just keep adding tape until they 'feel' the same.
2017 Scoring Model
CAD Library | GitHub
Unread 24-01-2017, 20:10
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
I just used b/c plywood with one coat of water based polyurethane then I sanded and put furniture wax on it. Works great
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 24-01-2017, 23:29
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
Or just spend $13.25 plus shipping and get HDPE to line your chute.
https://www.mcmaster.com/#8619k426/=1625apw
This is working great for us.
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 24-01-2017, 23:48
cj3958's Avatar
cj3958 cj3958 is offline
FRC #5234 (Marauderbots)
cj3958 will become famous soon enough
Imho everyone should just acquire some HDPE from Mcmaster. Its not that expensive(~20$ for a 2'x3' sheet) and it allows you to get a very similar experience you will get on the real field. If you find something at your local shop that has lower friction than the HDPE it is equally as bad as using plywood or polycarb. At the end of the day you want something that acts like the real field will act.
Current Lead Mechanical Mentor for 5234 the marauder-bots http://www.marauderbots.com/
Previously a student for one year on team 246 - Overclocked and 3 years on 3958 - Schodinger's Cat
Unread 25-01-2017, 00:18
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Grainger also has HDPE for slightly less and no shipping cost if you can pick it up at a local branch:
https://m.grainger.com/mobile/produc...searchBar=true
Once we found out our school district had an account with Grainger for the facilities group we have started leveraging it, better vendor for plastics on both cost and shipping if you usually rely on McMaster.
Unread 25-01-2017, 00:32
Bob Steele's Avatar
AKA: Bob Steele
We found that a material that is called "Starboard" which is used in marine applications among others is actually HDPE with the orange peel surface. We found it at TAP plastics.... it is SIGNIFICANTLY easier to slide the gears....on our practice version.... the gears actually slid all the way down without any push on the part of the human participant.
Regular HDPE is significantly different in that it has a noticeably higher coefficient of friction.
We are covering our retrieval stations with it... 1/4" pieces cost about $35 or so. (We picked it up at the store)
All told for 4 pieces it cost us $160 or so.... that was 4 pieces...
STARBOARD....
hmm I wonder if they also have PORT?
Unread 25-01-2017, 09:12
Billfred's Avatar
Billfred Billfred is online now
Originally Posted by Bob Steele View Post
STARBOARD....
That's for after ship day.
(I'm sorry I don't normally go off topic like this but I had to)
Unread 25-01-2017, 11:30
Pandaboy1293 Pandaboy1293 is offline
FRC #1293
Pandaboy1293 is an unknown quantity at this point
Does anybody know what the CoF of FRP? My team is using and I'm concerned that it might not work for what we need it to.
