Go to Post The sponsor had a $2000 sheet of aircraft aluminum in their scrap bin? Do they also blow stacks of dollar bills off their loading dock with a giant fan? - Richard Wallace [more]
Unread 21-01-2017, 14:24
erghost erghost is offline
FRC #4645
erghost is an unknown quantity at this point
Unhappy Cimcoders and Talons
We are having trouble figuring out how to connect cimcoder cables to the Talon SRX data port. Any ideas (besides using a breakout board)?
Thanks!
Unread 23-01-2017, 14:39
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
Re: Cimcoders and Talons
Maybe some more detail could help, but have you checked out the SRX User Manual and page 17?
https://content.vexrobotics.com/vexp...e-20150201.pdf
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
Unread 23-01-2017, 14:52
Billfred's Avatar
Billfred Billfred is offline
Thanks!
If we're talking the physical connection between the CIMcoder output and the Talon SRX, you're looking at either very carefully slicing up an SRX data cable to connect to the pins...or using a breakout board. The official CTRE encoder breakout board is going to provide a much easier target for a soldering iron to hit, though there's also MACH Engineering's universal breakout board that provides 0.1" pitch pins. If you can crimp connectors on the wires, that may be beneficial.
(Full disclosure of the probably obvious: I work at AndyMark, which sells both those boards, the CIMcoder, and the Talon SRX.)
Unread 23-01-2017, 15:16
MrNick's Avatar
MrNick MrNick is offline
FRC #0088 (TJ^2)
MrNick is an unknown quantity at this point
Note that pull-up resistors are required. See the CIMCoder data sheet. Our team just recently built a wire using the included CIMCoder wire, a TalonSRX breakout board and the resistors.
I would highly recommend the breakout board for the TalonSRX. They help quite a bit and make it easy to attach a variety of sensors to the Talon.
2016 Granite State District Event Winner
