Go to Post The one thing that no one ever list in scouting but is one of the most important factors is reliability. I don't care if the robot scores a hundred balls a match if I can't count on you being out there for the next three because it's a fragile as china. - Koko Ed [more]
Unread 23-01-2017, 15:40
wt200999's Avatar
wt200999 wt200999 is online now
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Class ADXRS450_Gyro output angles?
The angle is continuous, there is no code to wrap in the ADXRS library (so 360 to 361, or on the other hand, 0 to -1 etc). I attached the portion of code that does the actual accumulation which shows this is the case.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 23-01-2017, 16:22
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Is this the code that runs on the FPGA? If so, it never occurred to me that it would be written in LabView. I can see that all it really does is integrate the rate info over time. No real magic to it.
Thanks, this explains a lot.
Unread 23-01-2017, 18:05
wt200999's Avatar
Texas Instruments
AKA: Will Toth
The gyro code above runs in the background on the RIO itself (would be nice if it was on the FPGA, but doesn't happen in this case). You can find that code snippet if you look in the Gyro Open VI.
However I believe the FPGA implementation is also all done in LabVIEW using LabVIEW FPGA. Due to the parallel nature of LabVIEW it actually lends itself quite well to being compiled onto the FPGA.
