#7
Re: Class ADXRS450_Gyro output angles?
You don't need to invent anything when dealing with a continuous angle sensor. It's already been invented. The IEEEremainder function (supported in Java and C++) can take any angle and convert it to the range -180 to +180 You can also use it to find the shortest angle (magnitude and sign) between a setpoint and a process variable. |
