Go to Post it's not the bot that makes the team great, it's the team that makes the bot great. - alicen [more]
Unread 23-01-2017, 16:47
verlander13 verlander13 is offline
AKA: Ian
FRC #1025 (IMPIS)
Rookie Year: 2015
verlander13 is an unknown quantity at this point
Vision
Dos this code work?
package org.usfirst.frc.team1025.robot.subsystems;
import org.opencv.core.Rect;
import org.opencv.imgproc.Imgproc;
import org.usfirst.frc.team1025.robot.GripPipeline;
import com.ctre.CANTalon;
import edu.wpi.cscore.CvSink;
import edu.wpi.cscore.CvSource;
import edu.wpi.cscore.UsbCamera;
import edu.wpi.first.wpilibj.CameraServer;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.command.Subsystem;
import edu.wpi.first.wpilibj.vision.VisionRunner;
import edu.wpi.first.wpilibj.vision.VisionThread;
public class Vision extends Subsystem {
public static final int IMG_WIDTH = 320;
private static final int IMG_HEIGHT = 240;
private VisionThread visionThread;
UsbCamera camera;
public double centerX = 0.0;
//public RobotDrive drive;
public final Object imgLock = new Object();
public Vision() {
camera = CameraServer.getInstance().startAutomaticCapture() ;
// camera.setResolution(640, 480);
// CvSink cvSink = CameraServer.getInstance().getVideo();
// CvSource cvSource = CameraServer.getInstance().putVideo("Rectangle", IMG_WIDTH, IMG_HEIGHT);
visionThread = new VisionThread(camera, new GripPipeline(), pipeline -> {
if (!pipeline.filterContoursOutput().isEmpty()) {
Rect r = Imgproc.boundingRect(pipeline.filterContoursOutput ().get(0));
synchronized (imgLock) {
centerX = r.x + (r.width / 2);
visionThread.start();
//drive = new RobotDrive(1, 2);
public void initDefaultCommand() {
public Object getImgLock() {
return imgLock;
public double centerX() {
return centerX;
public int imageWidth() {
return IMG_WIDTH;
public int imageHeight(){
return IMG_HEIGHT;
Unread 23-01-2017, 16:48
AKA: Ian
FRC #1025 (IMPIS)
Rookie Year: 2015
Re: Vision
I also made a command going off of this
Unread 23-01-2017, 17:02
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Re: Vision
Depends what you're trying to accomplish. I'll note that the post-processing you're doing in the lambda assumes the first contour it sees is one of the boiler stripes, which may not always be the case.
centerX() should synchronize on the lock, otherwise the main robot thread may not get the most recent values (or any values at all. Threads are weird that way).
    return centerX;
WPILib
GRIP, RobotBuilder
Unread 23-01-2017, 17:06
AKA: Ian
FRC #1025 (IMPIS)
Rookie Year: 2015
Re: Vision
Thank you!
Unread 23-01-2017, 17:07
AKA: Ian
FRC #1025 (IMPIS)
Rookie Year: 2015
Re: Vision
Thanks. Does this command work with it?
package org.usfirst.frc.team1025.robot.commands;
import org.usfirst.frc.team1025.robot.Robot;
import org.usfirst.frc.team1025.robot.subsystems.Vision;
import edu.wpi.first.wpilibj.command.Command;
public class VisionAuton extends Command {
double centerX;
public VisionAuton() {
// Use requires() here to declare subsystem dependencies
// eg. requires(chassis);
requires(Robot.visionSubsystem);
requires(Robot.ChassisSubsystem);
// Called just before this Command runs the first time
protected void initialize() {
// Called repeatedly when this Command is scheduled to run
protected void execute() {
synchronized (Robot.visionSubsystem.imgLock) {
Robot.visionSubsystem.centerX = this.centerX;
double Turn = centerX - (Vision.IMG_WIDTH / 2 );
// ask
// Robot.chassisSubsystem.SimpleDrive(leftSpeed, rightSpeed);
Robot.ChassisSubsystem.getRobotDrive().arcadeDrive (-0.6, Turn * 0.005);
// Make this return true when this Command no longer needs to run execute()
protected boolean isFinished() {
return false;
// Called once after isFinished returns true
protected void end() {
// Called when another command which requires one or more of the same
// subsystems is scheduled to run
protected void interrupted() {
Unread 23-01-2017, 18:30
FRC #2084
Re: Vision
execute() won't work. You're overwriting the vision centerX instead of copying it. You should make the centerX variable in VisionSubsystem be private to avoid problems like this.
should be
  this.centerX = Robot.visionSubsystem.centerX();
isFinished should also return true when the robot's driven to wherever it should be. As is, the command will never finish and the robot will never stop.
WPILib
GRIP, RobotBuilder
Unread 23-01-2017, 20:39
AKA: Ian
FRC #1025 (IMPIS)
Rookie Year: 2015
Re: Vision
ok thanks
