Go to Post It's up to veteran teams and mentors to help keep the original spirit of FIRST alive. - It's up to us to make these boards exemplify the FIRST principals in every post. - Ben Mitchell [more]
Unread 24-01-2017, 00:42
ICE_Bear ICE_Bear is offline
FRC #5875 (ICE)
ICE_Bear is an unknown quantity at this point
Reusing Old Parts
Our robot from last year has a KOP piece of metal that was cut and could be cut and changed to make part of our robot for 2017. Is this legal according to the rule about not using things made before kickoff? Most of our team thinks we can, but just wanted some clarification that we can still use a basic piece.
Unread 24-01-2017, 00:54
JR0405's Avatar
JR0405 JR0405 is offline
Electrical & Pneumatics/Mechanical
AKA: Jack Ross
FRC #5822 (Wolfbyte)
Team Role: Driver
JR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to all
Re: Reusing Old Parts
It would have to be recut but it still can be used because of what the blue box on pg 63 says, "Note that it is possible for an item (typically raw materials) to be neither COTS nor a FABRICATED ITEM. For example, a 20 ft. length of aluminum which has been cut into 5 ft. (~152 cm) pieces by the Team for storage or transport is neither COTS (it’s not in the state received from the VENDOR), nor a FABRICATED ITEM (the cuts were not made to advance the part towards its final form on the ROBOT)."
#StaySavage
Unread 24-01-2017, 07:01
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
While not strictly what the words of the rules say, the key question from an intent standpoint is "am I leveraging the work I did to the piece last year?" Using a deburred square cut from last year which is no different (or inferior) to the factory state at one end of the robot is OK, but miter cuts, cuts to a specific length (e.g. if you cut an 8" piece of end sheet last year and use that same piece as 8" long again), or having holes drilled would mean that you are using it as an item created pre-season, violating the build schedule rules (R13).
Unread 24-01-2017, 08:20
maxnz's Avatar
maxnz maxnz is offline
AKA: Max Narvaez
FRC #2855 (BEASTBot)
Team Role: Student
Rookie Year: 2016
maxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of light
If all it is is something like the end plate from the KOP chassis and it was just cut shorter, then it is within the rules. If you drilled out some holes or added new ones, then you can't use that part of the piece.
One question I have is: what if you drilled a hole last year, but you drill out that hole larger this year? Would it be legal because you aren't using the hole from last year or is it illegal because the old hole helped you find where to drill the new hole? I'm leaning towards the latter but I'm not sure.
As a senior that will be leaving the team, I have to teach others how to:
1. Know the manual extremely well
2. Wire the robot
3. Organize the shop
4. Help people find parts when they need them
5. Find parts to order and give the detailed list to the coach in charge of buying the parts
6. Keep track of team updates, Q & A responses and FIRST blog posts
7. Be active on CD
8. Plan and execute drive team strategy
And more that won't fit on this list...
Unread 24-01-2017, 08:42
FrisbeeFunTime FrisbeeFunTime is offline
FRC #1768
Rookie Year: 2015
FrisbeeFunTime is an unknown quantity at this point
Have you considered asking this question on the official FIRST q&a. If you provide them all the info they need to know then you should get a definite sender on your question. Just add what you have done to the piece to the question such what you cut from it, hole that you've drilled if you did that, and pieces that you cut off to get it to fit somewhere if you used in on a prior robot.
Unread 24-01-2017, 08:48
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
If you do choose to ask this on the Q&A, you will need to phrase it very carefully. Usually the more general the better for Q&A questions. Too many specifics and they will answer "we won't rule on the legality of specific designs". Maybe you can word it as "What modifications are considered legal that parts modified from strictly COTS can still be used during the build season?" And then possibly list a few examples. Even then, I don't think it is very likely you will get the response you are looking for.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 24-01-2017, 08:57
FRC #1768
Rookie Year: 2015
Thanks for the correction.
