Go to Post Our robot name is currently "Subject to Change". - JesseK [more]
Unread 24-01-2017, 08:22
coach_erickin coach_erickin is offline
AKA: Erickin Zeng
FRC #6179 (PhotonBox)
coach_erickin is an unknown quantity at this point
Trouble in re-flash the OpenWRT firmware of radio
Hi,everyone.The problem appear when we trying to re-flash the firmware 2017. We re-flash the firmware fallow this link. It is success in 2016 on the om5p-an ,but now the om5p-ac is not right.
http://files.andymark.com/OM5P-AN_QuickAP_Setup.pdf
the problem appear in the section 2. When we use the ap51-flash.exe to re-flash the radio, it stop on the:
verify image pathpenwrt-15.05-ar71xx-generic-om5p-squashfs-factory.bin:combined ext image(3458215 bytes)
Listening on interface:\Device\NPF_<28c1887c-0ce2-4032-a63f-2ee999af43ac>
SOS
Unread 24-01-2017, 08:26
AKA: Erickin Zeng
Re: Trouble in re-flash the OpenWRT firmware of radio
verify image path: openwrt-15.05-ar71xx-generic-om5p-squashfs-factory.bin:combined ext image
(3458215 bytes)
Unread 24-01-2017, 12:13
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Are you attempting to program the radio for FRC use? If so follow this guide.
When you go to the link to download the FRC Radio configuration utility make sure you download the latest version (there have been patches since kickoff). If you need more detailed help, let me know and I will be happy to help.
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
Unread 24-01-2017, 13:56
zeldathegood zeldathegood is offline
FRC #4277
zeldathegood is an unknown quantity at this point
(3458215 bytes)
We have the same issue
Sent from my Pixel using Tapatalk
Unread 24-01-2017, 20:12
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
As far as I know, there is no reason to do it the "andymark way". Just simply download the FRC Radio Configurator and follow the instructions I posted above. Worked perfectly fine for us, we had the radio flash and programmed in minutes.
Unread 24-01-2017, 22:05
AKA: Erickin Zeng
Thanks for ur help!When we complete the installation,then gona use the FRC Radio Configuration Utility,we can't select the ethernet interface!We also try some other computers to use this software,still come the same question--no ethernet interface in the drop-down list!
Unread 24-01-2017, 22:22
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Make sure you turn your wifi off, and also make sure that the radio is plugged into your computer with a ethernet cable securely, and is also powered on. If you still can't see the "Local Area Connection" or "ethernet" selection in the drop down menu, go to your network settings and look at your network adapters to see if your ethernet adapter is disabled.
In order to go to network adapters in windows 10, right click on the network icon in the taskbar, click network and sharing center, then on the left click "change adapter settings". Now look for your ethernet adapter. If it is disabled for some reason, enable it. If you still need help let me know.
Unread 24-01-2017, 22:45
Try an english version of windows.
Unread 25-01-2017, 08:18
AKA: Erickin Zeng
Thank you for ur help!It really want english version of windows,we just finish it successfully !
