Go to Post I believe that FIRST in itself is a reward. - link871 [more]
Unread 24-01-2017, 08:59
thatnameistaken thatnameistaken is offline
AKA: Joshua Johnston
FRC #2191 (Flux Core)
thatnameistaken is on a distinguished road
Re: Programming Bulletin 873M Ultrasonic Analog Sensor
FWIW, the PCM can output 24V and does not have to be used exclusively for solenoids, if that makes your wiring any easier.
Unread 24-01-2017, 09:55
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Originally Posted by efoote868 View Post
Thanks for sharing your results!
This sensor is something I'd expect to find in a factory, wired to a relatively common 24vdc supply, not on a competition robot. It probably retails for way more than anyone would imagine.
We use industrial sensors on our bot all the time, as we are sponsored by and industrial controls integrator. I just don't understand how the picked this particular ultrasonic switch, as any of the discrete units are 10-30v operating voltage.
The sooner we get behind schedule, the more time we have to catch up.
Unread 27-01-2017, 21:25
loafdog loafdog is offline
AKA: Maciej
FRC #2876 (DevilBotz)
loafdog is on a distinguished road
I 2nd what @thatnameistaken said. In Logo Motion year there was some similar(same?) type of sensor to use to follow tape lines. Many teams including mine wired them to the pneumatics module of the crio to get 24V.
Unread 28-01-2017, 06:56
tr6scott's Avatar
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
Close but no cigar...
The cRIO was a 24vdc device, so the PDB in the cRIO years had a boost 12v to 24vdc built in. The power for 24v solenoids came from this supply too. There was a late rule change that allowed only these specific sensors to be wired to the 24v solenoid breakout.
The current canbuss pneumatic control module has a built in 12v to 24v power supply built in to power 24v solenoids, that is what @thatnameistaken was refereeing to, but I am not sure of the legality of using this supply to power 24v sensors. It has no terminals to distribute 24v power, so about the only thing you could do is wire the power from one of the solenoid connections and turn that output on continuously.
Not sure if this would be a legal use, wired this way, and I also did not see a current rating for the solenoid outputs in the PCM manual.
If you are set on using this sensor, I think I would be sourcing a 3rd part 12v to 24v dc boost brick.
Unread 28-01-2017, 21:15
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Not a great solution, but you could use a solenoid output from the pneumatics module. (Jumpers to 24V.) Downside is it will power off when the robot is disabled.
