Go to Post Check Chief Delphi, and if there isn't a post, make one. - sithmonkey13 [more]
Unread 17-01-2017, 20:21
Daltz3's Avatar
Daltz3 Daltz3 is offline
AKA: Dalton Smith
FRC #0066 (Grizzly Robotics)
Rookie Year: 2015
Daltz3 is an unknown quantity at this point
Raspberry Pi as Coprocessor
We plan on using the Raspberry Pi to do our vision processing. How would we output Python script results (after processing) and receive on RoboRio (Java)? I looked into pynetworktables and am confused on how to receive the data from the RoboRio.
Unread 17-01-2017, 20:28
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Re: Raspberry Pi as Coprocessor
GRIP has some examples. Specifically samples/frc_find_red_areas.
Basically, you just publish your results to NetworkTables with the pi connected to the roborio/radio/switch with an ethernet cable, then you can read that from your robot program.
WPILib
GRIP, RobotBuilder
Unread 24-01-2017, 09:49
ryan.mitchell ryan.mitchell is offline
FRC #1512 (Big Red)
Rookie Year: 2015
ryan.mitchell is an unknown quantity at this point
Hi, I am working on the same thing, but in Java. Is there documentation for Network tables in java?
Unread 24-01-2017, 09:57
FRC #2084
Javadocs here
WPILib
GRIP, RobotBuilder
Unread 24-01-2017, 09:59
FRC #1512 (Big Red)
Rookie Year: 2015
Thanks, could you take a look at this code I found on another thread:
//Robot Code
// declare object
NetworkTable cameraTable;
// getinstance (table is a singleton, if one does not exist then one will
// be created otherwise returns reference to existing instance
cameraTable = NetworkTable.getTable("camera");
// get data element from the table
// default values returned if no data has been provided from another source yet
cameraTable.beginTransaction();
Boolean imageFound = cameraTable.getBoolean("found", false );
Double imageOffset = cameraTable.getDouble("offset", -1.0);
Double imageDistance = cameraTable.getDouble("distance", -1.0);
cameraTable.endTransaction();
System.out.println( "found = " + imageFound);
System.out.println( "offset = " + imageOffset);
System.out.println( "distance = " + imageDistance);
// Driver Station PC
// camera image processing is done in C# application on DS
// declare it
private NetworkTable table;
// Init NetworkTable
NetworkTable.setIPAddress("10.6.23.2");  // ip of crio
table = NetworkTable.getTable("camera");
// in the image processing loop
table.beginTransaction();
table.putBoolean("found", true);
table.putDouble("distance", distance);
table.putDouble("offset", offset);
table.endTransaction();
[/quote]
Looks like what I need, but is it missing something (ie setTeam, etc.)?
Unread 24-01-2017, 10:24
FRC #2084
That example is 4 years old. All you have to do on the pi:
NetworkTable.setClientMode();
NetworkTable.setTeamNumber(1512);
ITable visionTable = NetworkTable.getTable("vision");
That'll set up the pi and a table specifically for vision. If you launch OutlineViewer from Eclipse (WPILib > Launch OutlineViewer), you'll be able to see the values update in realtime.
Then to publish the results from the vision processing
visionTable.putBoolean("Have target", haveTarget);
visionTable.putNumber("Angle to target", angleToTarget);
In your robot program, you'd also declare a table for vision just like we did on the pi. To read the values the pi is publishing, use the corresponding 'get' methods
haveTarget = visionTable.getBoolean("Have target", false); // default to false
targetAngle = visionTable.getNumber("Angle to target", 0); // default to 0
WPILib
GRIP, RobotBuilder
Unread 24-01-2017, 10:26
FRC #1512 (Big Red)
Rookie Year: 2015
Thank you so much!
Unread 29-01-2017, 23:23
zeldathegood zeldathegood is offline
FRC #4277
zeldathegood is an unknown quantity at this point
Does anyone know of a vision processing tutorial?
Sent from my Pixel using Tapatalk
