Go to Post It's rather simple: you start with a block of solid and remove material until you just have the robot left. Kind of like making a sandcastle. Only harder. - petek [more]
Unread 20-12-2016, 15:54
gbear605's Avatar
gbear605 gbear605 is offline
Scarebear
FRC #1768 (Nashoba Robotics)
gbear605 is an unknown quantity at this point
SmartChart (Graphing Plugin for SmartDashboardFX)
As we've used SmartDashboard 2.0 (SFX) over the last two years, we've found that the built-in graphing utility just isn't good enough, so we made our own version.
It can be found at https://github.com/Nashoba-Robotics/SmartChart
Advantages:
  • Graphs based on time, instead of based on when a new data point is sent to the dashboard
  • Graph can be reset
  • Graph can show multiple data sets simultaneously, by sending SmartDashboard a string with the format "[var1]:[var2]:[var3]". Eg. "1.0:2.3:5.6"
  • Graph can export data to a csv file in the location USER_HOME_DIRECTORY/SmartDashboard/VARIABLE_NAME.csv
To install, download the most recent release, and move the .jar to your USER_HOME_DIRECTORY/wpilib/tools/plugins/ folder.
BONUS: In the repo, there's also a SmartDashboard USB Camera extension that flips the image upside down, so if you have an upside-down camera on your robot, the output is more useful for your drivers.
Unread 20-12-2016, 16:07
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: SmartChart (Graphing Plugin for SmartDashboardFX)
We used this last year. It was super useful (even when the rest of SFX wasn't really all that great)
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 23-01-2017, 18:03
gbear605's Avatar
Scarebear
We've now added zooming as a feature as well. So far it is only available when not graphing multiple data sets simultaneously, but that is planned.
Unread 24-01-2017, 10:43
gbear605's Avatar
Scarebear
We just added zooming while graphing multiple data sets.
