Go to Post When's the last time you called up FIRST headquarters just to say thanks? Or saw a volunteer at a regional and said, 'Hey, you're doing a really great job here. Thank you for everything you're doing in your spare time.' - Amanda Morrison [more]
Unread 24-01-2017, 11:41
cyberius cyberius is offline
FRC #6017
cyberius is an unknown quantity at this point
Proximity Sensors for FRC?
Hi guys, I would really appreciate your help with finding the right proximity sensors to buy for the 2017 FRC competition. This is just my team's second year participating in FRC, and we really don't have much experience on the subject. We were thinking of using the sensors for guiding our robot during the autonomous period, and need them to be able to detect surfaces at approximately 3/4 meters away. What type/brand of sensor do you recommend that we buy? Which are compatible with the NI roboRio? Any help is appreciated, and thanks in advance!
Unread 24-01-2017, 11:46
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Re: Proximity Sensors for FRC?
Our team happens to have a fleet (literally) of HC-SR04 ultrasonic sensors. They're extremely cheap, have built-in software support in wpilib, and we have tested them to measure accurately from about 5 cm to several meters away. This will be our first year using them in an FRC robot, but we've used them in smaller robot projects.
"If I'm going to mentor someone, I'm going to be involved in their life as a positive force." -Mechvet
Unread 24-01-2017, 15:21
dk5sm5luigi's Avatar
dk5sm5luigi dk5sm5luigi is offline
AKA: Nick Galotti
FRC #1735 (Green Reapers)
dk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud of
Send a message via AIM to dk5sm5luigi
It might be worth looking through the sensors listed here: http://findrobotparts.com/sensors/
These are all sensors used by teams.
Team 1735 Green Reapers: 2005-Present
Team 190 Gompei: 2001-2005
Team 155 Technonuts: 1997-2001
http://www.first-a-holics.com/
http://www.findrobotparts.com/
Unread 24-01-2017, 15:56
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
At that range it really boils down to ultrasonic or light sensors. They both have their own idiosyncrasies with regards to the material they are hitting and reflecting from, their response rate, the object size detection, and the noise they may see. Most of the issues are listed in various posts here that you can search for.
The most common ultrasonic sensor is the maxbotix sensor. I believe you received one in your kit of parts.
