Go to Post Honestly, I can't understand why anyone wouldn't want to be a mentor. The fools don't know what they are missing. - Steven Smith [more]
Unread 23-01-2017, 07:10
Noam Noam is offline
None #3034 (galileo)
Rookie Year: 2015
Noam is an unknown quantity at this point
image processing using opencv - how to combine with the bobot code
I have code for image processing using opencv, and i'm trying to combine it with the robot code - now I have just a opencv program, that find the reflective (and the size and the position of the reflective) - when the camera is connected to the computer. How can I combine the opencv code, with the robot code ?
Thanks in advance
Unread 23-01-2017, 07:23
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: image processing using opencv - how to combine with the bobot code
OpenCV is now included in WPILib projects. So just copy and paste your OpenCV processing code into your robot program, and use cscore to get Mats from a USB or AXIS camera connected to the roboRIO.
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 24-01-2017, 11:01
Rookie Year: 2015
oh ok thanks
so what I need to write instead of mat, rect, imgproc, matofpoint, matofpoint2f, cvtype, scalar, size, and etc..?
Unread 24-01-2017, 11:31
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
You can use GRIP to generate code straight into your robot project. See the Screensteps pages
WPILib
GRIP, RobotBuilder
Unread 24-01-2017, 16:19
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
Originally Posted by Noam View Post
oh ok thanks
Nothing. As I said already, OpenCV is included. So go ahead and use mat, rect, imgproc, etc
