Go to Post sometimes you have to put up with the rain to see the rainbow - Beth Sweet [more]
View Poll Results: What gets harder at Champs?
The 4-rotor bonus will be made harder. 59 36.20%
The full steam bonus will be made harder. 39 23.93%
Both will be made harder. 39 23.93%
Neither will be made harder. 26 15.95%
Voters: 163. You may not vote on this poll
Unread 24-01-2017, 09:59
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
Re: What gets buffed or nerfed this year at DCMP/CMP?
Originally Posted by Andrew_L View Post
Reserve and pre-placed gears will not start on the tower.
Originally Posted by PayneTrain View Post
The only thing that I would put even odds on happening is the death of the gimme gear that sits in the tower by the time late April rolls around.
So they already talked about how the reserve gear is there for thematic reasons (how can the three robots climbing the rope prepare for take off on an airship with no moving rotors?) but it actually also helps keep the game balanced in a 3 fuel vs 3 gear robot battle.
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
Unread 24-01-2017, 16:54
GaryVoshol's Avatar
Cogito ergo arbitro
The Reserve GEAR is not treated the same in the rules as a Pre-Populated GEAR. I don't think there's any provision to not have the Reserve GEAR in place for championships.
Also, if the Pre-Populated GEARS are removed for DCMP or CMP, I don't think there's any provision to add them to the ALLIANCE's supply of GEARS. They'd just go away.
(since 2004)
Unread 24-01-2017, 20:13
New Lightning's Avatar
New Lightning New Lightning is offline
Master of Tactics
AKA: Scott Hasek
FRC #1987
New Lightning has a spectacular aura aboutNew Lightning has a spectacular aura about
I think that in order to increase game difficulty the most likely scenario would be to remove the pre-placed gears. It makes the amount of effort required to get the larger value of additional points in eliminations much more of a challenge.
The other thing that I speculate could happen, and I apologize I haven't looked too closely at this section to know if they could, is that they would raise the threshold ratio in auto for balls from 1-1 to 1-3 for 1kPa, the same as it is in teleop for high goals. This makes the challenge of getting the additional bonus points just in auto harder, and therefore increases the amount of balls that you would have to put into the high goal, and even more if you were going into the low goal.
