Go to Post FIRST showed me how to succeed at one of the most difficult, yet important things: Life. - Jim McGeehin [more]
Unread 24-01-2017, 20:48
generaldgibson generaldgibson is offline
generaldgibson
AKA: Daniel Gibson
FRC #3397 (FRC Robolions)
Rookie Year: 2015
generaldgibson is an unknown quantity at this point
No Robot Code on RoboRIO
Last week our test RIO was running fine, we were deploying basic code and getting prototypes working just fine. But now the RIO is saying that there is no robot code on the RIO, even though I downloaded code onto the RIO with no problems. I made sure the RIO has the latest versions of Java and the RIO image (unless there's a new RIO image version I hadn't heard about). I searched the topic and tried the trick where you plug the joystick into slot 5 on the DS, that didn't work either. I'm really stumped about why this isn't working. Any help would be appreciated, thanks!
Unread 24-01-2017, 20:50
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
Re: No Robot Code on RoboRIO
It looks like your code is crashing. Does the Driver Station console have any messages in it?
Unread 24-01-2017, 20:54
generaldgibson
AKA: Daniel Gibson
Rookie Year: 2015
Yes, I was getting this from the driver station.
ERROR Unhandled exception: java.lang.NullPointerException at
[edu.wpi.first.wpilibj.CameraServer.addCamera(Camer aServer.java:785),
org.usfirst.frc.team3397.robot.Robot.robotInit(Rob ot.java:45),
edu.wpi.first.wpilibj.SampleRobot.startCompetition (SampleRobot.java:117),
edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:247)]
Unread 24-01-2017, 20:56
AKA: אוסטין
It looks like you have a NPE. If you send me your code (As a zip please), I can take a look.
Unread 24-01-2017, 20:57
generaldgibson
AKA: Daniel Gibson
Rookie Year: 2015
Looking at it again, it seems like a lot of problems are stemming from the CameraServer. I noticed that there were some new classes for using the camera this year, but I couldn't ever find a solid guide on how to implement camera - the stuff I did use was a bit confusing.
Unread 24-01-2017, 21:23
generaldgibson
AKA: Daniel Gibson
Rookie Year: 2015
Code should be attached here
Unread 24-01-2017, 21:27
AKA: אוסטין
Try this on line 45:
cam1 = server.startAutomaticCapture();
Unread 24-01-2017, 21:31
generaldgibson
AKA: Daniel Gibson
Rookie Year: 2015
That worked. I had a feeling it was the camera, thanks for the help!
