Go to Post We are in the business of teaching our students. One of those things should be respect for the rules... - Tuba4 [more]
Unread 25-01-2017, 11:12
GDG 2337 GDG 2337 is offline
FRC #2337 (ENGINerds)
GDG 2337 has a spectacular aura aboutGDG 2337 has a spectacular aura about
pic: Toughbox Mini Bound Up On AM14U3 KoP Chassis
Unread 25-01-2017, 11:15
Joining the 900 Meme Team
FRC #0079
Re: pic: Toughbox Mini Bound Up On AM14U3 KoP Chassis
George, thanks for documenting this. We ran into similar binding issues Monday night, students reported it was a similar issue but I, frankly, just assumed it was they'd forgotten to lubricate something.
Now that you're seeing similar issues I'm concerned that others are too. Which is a shame, otherwise the AM14U3 has seemed pretty solid.
Unread 25-01-2017, 12:58
M.O'Reilly M.O'Reilly is online now
AKA: Mike O.
FRC #4637 (BambieBotz)
M.O'Reilly is a glorious beacon of lightM.O'Reilly is a glorious beacon of lightM.O'Reilly is a glorious beacon of lightM.O'Reilly is a glorious beacon of lightM.O'Reilly is a glorious beacon of light
Our team also experienced binding in one of our transmissions. We disassembled, re-assmbled, and wheels spun without much resistance. Have not driven on them yet though, so can't be sure this problem has been totally resolved (since we didn't really do anything except re-seat bearings and gears )
Thanks for bringing your investigation to our attention.
Unread 25-01-2017, 14:22
In this case the Tough box Mini housing would not set flush to the rail, so when the housing was tightened, the gear box bound up. The bearing was bottoming out in the bore with the hex bearing and output shaft gear correctly installed.
Unread 25-01-2017, 16:37
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Thanks for the heads up!
We had a TB-mini bind up near the end of build yesterday. We checked the obvious stuff like gears installed backwards (bosses together instead of at bearings), but not this. We just replaced the gearbox with one we had build for the second robot and moved on, and we'll look at the binding gearbox tomorrow. (no build today.) I'll be sure we check for this early in the process.
Unread 26-01-2017, 13:26
jodocsingh jodocsingh is offline
FRC #0948
jodocsingh is an unknown quantity at this point
We had a similar problem on a practice base that was constructed for our programming team during our training season. We never looked much into this, its good to know of this issue. Will look into it once the season is over!
Unread 26-01-2017, 14:29
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
Thank you for the heads up. This is great to know as we begin to test our drive base. Would you be willing to link to where we could purchased the thinner bearing?
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 26-01-2017, 14:45
Clinton Bolinger's Avatar
Clinton Bolinger Clinton Bolinger is offline
FF - PureMichigan
FRC #2337 (EngiNERDs)
Clinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond repute
This should be one source: https://www.bocabearings.com/product...z-w-2188c-1901
Hope this helps,
Clinton
Unread 26-01-2017, 14:49
mastachyra's Avatar
mastachyra mastachyra is offline
FRC #2781 (RoboPride)
mastachyra is just really nicemastachyra is just really nicemastachyra is just really nicemastachyra is just really nice
Thanks for posting this! Our robot was jerking to the right last night and I was going to begin the investigation today. This is the first place I'll look.
2014: EtaBot - MWR/30th place/no PO
2015: ThetaBot - MWR/30th place/no PO, R2OC/Winners, IndyRAGE 5th Alliance, WMRI QF
2016: IotaBot - MWR/16th place/QF, R2OC/7th Alliance Captain/QF, Boiler Bot Battle/6th place/Finalist
Unread 26-01-2017, 14:55
mastachyra's Avatar
http://www.andymark.com/product-p/am-0936.htm
This bearing is not shielded, but it has the right dimensions. I can't remember for sure, but I think this bearing is pretty well protected in the gear housing, so I don't think the shielding should be much of an issue. I'm sure someone will correct me if I'm wrong about that.
Unread 26-01-2017, 15:23
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
I would not risk using an unshielded bearing. If this game is even half as bad as 2014 your steel gears will have a ton of wear by the end of the season, that leads to steel powder in the gearbox, i have no idea what the poweder would due to an open bearing but i would suggest we not find oit. I know that vex has bearings with a 3/8 ID that are shielded that I believe would fit.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 27-01-2017, 12:19
mastachyra's Avatar
I think the Vex bearings that would "fit" are the same thickness as the ones GDG 2337 pointed out above as too thick. You'll need to find the 0.218" thickness. McMaster-Carr does not have this bearing in shielded form either.
Unread 27-01-2017, 12:40
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I'm confused....we had several of our new students assemble our kit chassis this week, and I was watching over them quite a bit. I did notice that the bearings are thicker than the machined portion of the hex shaft, as shown in your photo. But we were very careful to assemble the transmissions as the instructions say, and they worked fine, no binding.
I know in the past we've had trouble with the gearboxes, when I was not so involved with the assembly (but did help with the diagnosis and reassembly), and we've had problems with gears installed backwards causing binding.
I really don't think that a thinner bearing is needed. But I also did not measure the shaft. Have you compared the dimensions of the questionable shaft, with those on the AM drawing?
http://files.andymark.com/AM-2566%20...haft%20Hex.PDF
Unread 28-01-2017, 00:20
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
As we were trying to free our bound out TB Mini yesterday, I am trying to figure out how too short a journal would cause a problem with seizing, as it does not make contact with the plastic housing in either case. I am even more curious as to how you put a thinner bearing in and did NOT cause the bull gear to rub against the large cluster gear; they are rather close to each other with the stock bearing. This would only be feasible if, rather than the journal being cut too short, the hex part of the shaft is cut too long.
On our TB-mini, the binding is certainly not from the output shaft or bull gear; it occurs from time to time when back-driving the cluster shaft with a 3/8" socket. The binding appears to be due to the large cluster gear rubbing against the output shaft bearing (in the plastic housing). We tried swapping out the large cluster gear (slight improvement?), swapping the two bearings in the housing (no difference), and will try swapping the face plate and plastic housing tomorrow on the suspicion that the bearing holes have the wrong spacing on one or the other.
Unread 28-01-2017, 14:36
Guess I’ve done a poor job communicating the issue, a better way would have been as GeeTwo has stated
“This would only be feasible if, rather than the journal being cut too short, the hex part of the shaft is cut too long.”
Or when the round journal was turned on the hex shaft, normally from .520 to .780. It is only turned from .520 to .720, making the bearing extend .60 farther into the Mini housing. Which was corrected by installing a thinner .220 bearing replacing the .280.
