Go to Post It doesn't matter what material you pick, it matters how you execute your design. - JamesCH95 [more]
Unread 25-01-2017, 14:49
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Efficient Points
Originally Posted by Ginger Power View Post
TL;DR: Designing your robot to handle solely Gears is risky because you're dependent upon alliance partners to achieve a Rotor advantage vs. the opposing alliance.
The tricky thing with comparison, and you mentioned it, is autonomous. Gear specialists can (probably) count on 3 easy gears (plus the spare). Non-specialists can't, unless they find SWAP for a gear ground intake.
You make a good point though. It seems like the MCC for a gear specialist is a reliable auton and then at least 3 full-field gear cycles under even the heaviest of defense (2v1). Other than that, I'm not sold that it's riskier than over-extending a team's capabilities by doing more mechanisms and dividing attention during an event. This bias is based upon my team's history of over-extending.
With an all-gear Quals alliance as you described, I'd probably start the match with an understanding that we would attempt 4 rotors and adapt from there with preset milestones and knowing who would play what defense if a call was made to abort. The gameplay strategies (and a little luck in execution) are the secret sauce for making 4 rotors work in that situation, so I won't reveal too much .
2017 Scoring Model
CAD Library | GitHub
