Re: Change in 25HD chain?
Some method of tensioning the chain is always recommended by the manufacturers
http://www.renoldjeffrey.com/nmsrunt...=1019&sID=2750 Page 229 Chain Adjustment To obtain full chain life, some form of chain adjustment must be provided, preferably by moving one of the shafts. If shaft movement is not possible, an adjustable idler sprocket engaging with the unloaded strand of the chain is recommended. Generally the idler should have the same number of teeth as the driver sprocket and care should be taken to ensure the speed does not exceed the maximum shown in the Quick Selector Chart (see page 234). The chain should be adjusted regularly so that, with one strand tight, the slack strand can be moved a distance “A” at the midpoint (see diagram below). To cater for any eccentricities of mounting, the adjustment of the chain should be tried through a complete revolution of the large sprocket. A = Total movement C = Horizontal center distance Total movement “A” (in.) = C (in.) K Where K = 25 for smooth drives 50 for shock drives |
