Am I sending you the right signals?
  #31   Spotlight this post!
Unread 25-01-2017, 12:20
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Re: Gear Sliding down Ramp
I have no idea how it compares to the real thing, but we put on a layer of 1/8" hardboard, smooth side up, and it slides pretty well on that.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
  #32   Spotlight this post!
Unread 25-01-2017, 15:14
Bob Steele's Avatar
AKA: Bob Steele
Originally Posted by Pandaboy1293 View Post
Does anybody know what the CoF of FRP? My team is using and I'm concerned that it might not work for what we need it to.
Take a piece of FRP put a gear on it... lift it up on one end and record the angle at which the gear begins to slide. The tangent of that angle is the STATIC friction coefficient. That can be compared to other static coefficients. The static coefficient of friction is always greater than the kinetic coefficient of friction. Remember that these coefficients are based on two materials....so there is no "Coefficient of Friction" for FRP.... it would have to be FRP and carpet, or FRP and wood or something...
good luck!!
If anyone actually does this for both FRP and the orange peel HDPE I would be interested in seeing what that number is.
  #33   Spotlight this post!
Unread 25-01-2017, 16:54
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Not those numbers, but we did measure the CoF of a gear with an actual FRC (2015) carpet yesterday (laying flat) using the well-known ramp method, finding it to be 0.43*. Static and dynamic were indistinguishable; once the gear started it moved at a slow steady rate down the ramp. As the gear weighs 18.4 oz per the game manual, expect to have a frictional force of about 8 oz.
* 39" long piece of plywood backing, hand raised, tape measure measurements, so you might want to put around a +/- 0.02 on it.
  #34   Spotlight this post!
Unread 25-01-2017, 16:58
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond repute
We have some HDPE for our feeder station, took some video of the gear going down if anyone is interested in that. I apologize now for it being in a bad orientation, didn't pay attention at all when i recorded.
Unpushed
Pushed
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
  #35   Spotlight this post!
Unread 25-01-2017, 21:01
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Unpushed
Pushed
Running these side-by-side, my perception is that your unupushed video is slower than field tour. Is that just because of the video angles (the field tour going out of frame soon)? I haven't tried to break it down frame by frame.
  #36   Spotlight this post!
Unread 25-01-2017, 21:04
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Field tour vids make the surface look matte. This looks shiny?
Did you have "orange peel" HDPE?
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
  #37   Spotlight this post!
Unread 25-01-2017, 21:10
XtremeFate XtremeFate is offline
FRC #4505
XtremeFate is an unknown quantity at this point
We just took some fine sandpaper to our polycarbonate and it slides very well. Seems that the glossy surface was sticking to the gear somehow.
  #38   Spotlight this post!
Unread 25-01-2017, 22:35
MikLast's Avatar
CAO/Drive Coach
Dont know off the top of my head. Ill ask someone who knows tomorrow.
Natural HDPE.
