Go to Post I'm going to get kicked out of the mentor club for this one... - Not2B [more]
Unread 24-01-2017, 17:20
SeelPatel SeelPatel is offline
FRC #4903
SeelPatel is an unknown quantity at this point
OM5P-AC Router Setup Issue
We did what was on the website and it didn't work. We went through the setup without any errors. But the router has a red indicator light for the wireless LED (Access Point, but Unlinked) an the router does not broadcast any wireless signal at all. We setup our first router with the same process and it worked.
What we tried:
-Manually set static ip
-Different configuration settings
-Resetting router
-Running in administrator mode
-Using different cables
Could i be a defective router? have any of you had this issue?
Unread 24-01-2017, 20:32
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
Re: OM5P-AC Router Setup Issue
Have you tried connecting to it from another device?
Unread 25-01-2017, 15:35
FRC #4903
We could try, but it won't broadcast a wireless signal
Unread 25-01-2017, 16:22
TylerHarmon's Avatar
TylerHarmon TylerHarmon is offline
TylerHarmon is an unknown quantity at this point
Do a fresh reimage from the documentation. Make sure you don't use the Israeli version (unless you are in Israel) because they have a different IP standard than other countries.
