Originally Posted by beijing_strbow
When I try to connect to the web dashboard everything shows up fine. However, when I go to the device settings page and click on a device to change the settings, it says the device can't be found and to check whether it's connected to the network. It does this even for the roboRIO itself.
I'm using Internet Explorer, and "device settings" is checked as an enabled feature on the installed features page.
Any help would be much appreciated.
If the device can't be found, it could be an electrical problem. Check the CAN wiring for all devices. If you can't see
any devices, the beginning of the can bus could be damaged, so double check that the roboRIO is correctly sending CAN traffic.
