Go to Post No matter what route you choose, it's always a good idea to keep Mike Walker's cell phone on speed dial. - Joe Ross [more]
Unread 25-01-2017, 18:07
Leslieann Gomez's Avatar
Leslieann Gomez Leslieann Gomez is offline
FRC #4571 (Rambots)
Rookie Year: 2015
Leslieann Gomez is an unknown quantity at this point
Re: SmartDashboard SFX Help
I have actually thoroughly read through the documentation; I just don't find it very helpful. That's why I am asking for alternative resources. Perhaps those will be of greater help.
Unread 25-01-2017, 18:33
david.e.boles david.e.boles is offline
Bringer of Whales and Petunias
AKA: david476
FRC #5940 (BREAD)
david.e.boles is on a distinguished road
SmartDashboard just uses a table of key (name) value pairs sent over the network from your robot. When you put data into the table it automatically creates a widget to display the value. Widgets can also display other things (like a MJPEG camera stream) and be deleted, moved and resized. That's about it!
Unread 25-01-2017, 18:57
TylerHarmon's Avatar
TylerHarmon TylerHarmon is offline
TylerHarmon is an unknown quantity at this point
If you want to print out a number, for example, you would type
SmartDashboard.putNumber("nameForNumber", numberValue);
Then, run SmartDashboard.jar and you should be able to see those values.
