Go to Post Heck, I gave several [E-Saver Lightbulbs] away as Christmas presents... - DonRotolo [more]
Unread 25-01-2017, 16:02
Leslieann Gomez's Avatar
Leslieann Gomez Leslieann Gomez is offline
FRC #4571 (Rambots)
Rookie Year: 2015
Leslieann Gomez is an unknown quantity at this point
SmartDashboard SFX Help
This is our team's first time really implementing SmartDashboard. I'm a little confused as to how it functions and how to put values onto it. Any resources apart from the screen steps would be great to know about. Thank you!
Unread 25-01-2017, 16:18
TylerHarmon's Avatar
TylerHarmon TylerHarmon is offline
TylerHarmon is an unknown quantity at this point
Re: SmartDashboard SFX Help
The screen steps here explain it very well.
Don't ask questions like this until you have read the documentation. If you read the docs for 2 minutes I guarantee all of your questions will be answered.
Unread 25-01-2017, 18:07
FRC #4571 (Rambots)
Rookie Year: 2015
I have actually thoroughly read through the documentation; I just don't find it very helpful. That's why I am asking for alternative resources. Perhaps those will be of greater help.
Unread 25-01-2017, 18:33
david.e.boles david.e.boles is offline
Bringer of Whales and Petunias
AKA: david476
FRC #5940 (BREAD)
david.e.boles is on a distinguished road
SmartDashboard just uses a table of key (name) value pairs sent over the network from your robot. When you put data into the table it automatically creates a widget to display the value. Widgets can also display other things (like a MJPEG camera stream) and be deleted, moved and resized. That's about it!
Unread 25-01-2017, 18:57
If you want to print out a number, for example, you would type
SmartDashboard.putNumber("nameForNumber", numberValue);
Then, run SmartDashboard.jar and you should be able to see those values.
